Page 1 of 1
Way to start and stop an inverter
Posted: Thu, 11 Apr 2019, 13:31
by hary
Hi everyone.
I've videos were people start or stop load already plugged in inverter from the inverter"s switch interrupter.
Is that a way to go with no bad side effect ?
Or should be the inverter started first, then plug the load, use it, unplug the load and last switch OFF the inverter ?
Re: Way to start and stop an inverter
Posted: Thu, 11 Apr 2019, 14:22
by coulomb
Inverters seem to be happy starting with a load connected. So I don't think it matters.
Posted: Wed, 31 Jul 2019, 19:58
by doggy
Hello Harold,
I have now used my inverter, which is almost the same as yours, quite a bit now. I have turned it on and off in all possible ways. When charging my EV from it, the BMS interrupts the battery connection to the inverter when any cell reaches 2.8V.
I can start the inverter with load attached or not. I can turn on the inverter with load attached then use the contacter to connect the battery. No problem.
Because the inverter "slow starts" when turned on (in any manner) everything seems fine no matter how I do it.
When running tools, heaters, fans etc I normally turn it on and off with the inverter remote switch.
Regards,
Posted: Tue, 31 Dec 2019, 08:38
by robeyw
It depends highly on the inverter. Some have "soft start" to varying degrees. Starting it with an incandescent light won't be a problem but starting a motor will. Stoping is another mater. For a well designed inverter, I don't think it matters but I encountered one (from Yueqing Reliable Electric Co.) that would sometimes blow a MOSFET apart on shutdown so the best way to turn it off was to disconnect the DC input, leaving minimal stored energy in it for destructive purposes.
