Axpert mks vm2 error code 51
Ibrahimfr
Post by Ibrahimfr »
Hi
i glad to be a member of this community , thank you everybody .
i have a problem with my axpert vm2 5kva device , it shows error code 51 and then turning off .
what the electronic component can cause this failure ?
i will be very happy if i can fix it.
Re: Axpert mks vm2 error code 51
Ibrahimfr wrote: Thu, 07 Feb 2019, 22:09
I believe that the Axpert VM IIs are similar to the PIP-5048MS, except for the MPPT voltage and a few changes to make them economy models. So, presumably similar in ways that are important for fault code 51, "Over current or surge". On the PIP-5048MS (etc) index page, there are five links to posts about that fault code, which might give you some clues. My particular theory (per one of the five sets of posts), is that the MOVs' conduction voltage decreases as they absorb energy, and replacing them might fix the problem. I have links to suitable replacement parts for the PIP-5048MS; with reasonable luck these might be the same parts as in the Axpert VM II.
Are you in a lightning prone area?
[ Edit: "PIP-5048s" -> "PIP-5048MS" (more specific, less confusion). ]
eng.bajes
Post by eng.bajes »
eng.bajes wrote: Wed, 15 Jan 2020, 03:03 i have a problem with my axpert vm2 5kva device , it shows error code 51 and then turning off .
Error code 51 is "Over current or surge". Could it be some device starting up with a high surge current, putting the inverter into overload for just a short time? I'm not totally convinced that we always get to use the 100% overload for 10 seconds thing.
Or does it not come back on when restarted?
I suggest using the forum search to search on "error 51" without the quotes. There many posts about this in other topics.
eng.bajes
Post by eng.bajes »
weber wrote: Wed, 15 Jan 2020, 12:22
I made many attempts but it did not work out
eng.bajes
Post by eng.bajes »
coulomb wrote: Fri, 08 Feb 2019, 07:00
I switched all (MOV) but the problem was not solved
