Batrium BMS Monitoring
bigjsl
Real Name: John Lindsay
Post by bigjsl »
Hope this is the right place to post this.
I wrote a bit of python3 to monitor my Batrium BMS.
You can modify it using info here: https://github.com/Batrium/WatchMonUdpL ... 20v1.0.pdf
I plan to incorporate it into my pvoutput upload script.
# Batrium UDP monitor in Python3
# John Lindsay
import select, socket
import struct
port = 18542  # where do you expect to get a msg?
bufferSize = 1024 # whatever you need
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.bind(('',port))
s.setblocking(0)
byterecord = struct.Struct('B')
intrecord = struct.Struct('H')
floatrecord = struct.Struct('f')
global got_soc
got_soc = False
global got_volts
got_volts = False
completed = False
while not(completed):
    result = select.select([s],[],[])
    msg = result[0][0].recv(bufferSize)
    if msg[:3] == b'\x3a\x33\x3f':
      battery_soc=((float(byterecord.unpack(msg[32:33])[0])/2)-5) # byte -5% to 105% 0.5% per bit => /2 - 5
      got_soc = True
    if msg[:3] == b'\x3a\x32\x3e':
      battery_min = intrecord.unpack(msg[8:10])[0]/1000.0  #Uint16 x 1000
      battery_max = intrecord.unpack(msg[10:12])[0]/1000.0  #Uint16 x 1000
      battery_bypass_count = (byterecord.unpack(msg[33:34])[0])
      battery_volts = intrecord.unpack(msg[40:42])[0]/100.0  #Uint16 x 100
      battery_amps = floatrecord.unpack(msg[42:46])[0]/1000.0 #float4 x 1000
      got_volts = True
    completed = (got_volts and got_soc)
print ("soc%:",battery_soc)
print ("min:", battery_min)
print ("max:", battery_max)
print ("bypass:", battery_bypass_count)
print ("volts:",(battery_volts))
print ("amps:",(battery_amps))
bigjsl
Re: AVASS Battery order details
Post by bigjsl »
It produces output like this:
soc%: 79.0
min: 3.28
max: 3.32
bypass: 0
volts: 52.67
amps: -12.2866875
rhills
Real Name: Rob Hills
Re: Batrium BMS Monitoring
Post by rhills »
Hi John,
The topic you originally posted this in (AVASS Battery Order Details wasn't really the right place for it. That wasn't your fault as it had been starting to wander off the original subject anyway so I have now locked it.
I think your posts deserved their own topic, so I created one for them.
Total Petrol: 756.3L
ODO: 67508
Av Consumption: 1.12 L/100km
Also, if you want to post code you can do it using this feature:
Code: Select all
Code code code {stuff}
More code more code more code
colon slash break curly braces etc.
Using the [c0de] blah [/code ] (with an 'o' instead of a zero, obviously)
