Dash Cam on Highlander
Hyundai Interest Group
ingk
Post by ingk »
Got the Highlander today. Cannot figure out how to mount a dash cam. The usual spot behind the mirror is not available due to the large cover for the forward facing camera and sensor for collision protection. Plus the very solid electronic mirror.
This area has to be kept clear for hyundai service . Plus warnings not to make changes in the area.
Seems that top right hand or lefthand corners of screen are the only neat option.
Has anyone fitted a dashcam yet
Re: Dash Cam on Highlander
Not yet but will do very shortly...
photomac
Real Name: Matthew Clifton
Post by photomac »
We lashed out and got the Hyundai Osbourne Park offer for front...
and back...
By Blackvue
They are stuck to the glass.
If any help to you 🧐
Yes,   we can.   Image
Kangavue
Post by Kangavue »
photomac wrote:
Sat, 07 Sep 2019, 12:21
and back...
By Blackvue
Can I ask what power supply the dash cam tapped into? OBD? Will there be much battery drain when the recording switches on and off when parked, if it records pedestrian activity at the front? I thought this’d be handy when leaving car with charger cable inserted.
Dash cams generally draw next to nothing so unless you leave the car for a week (or more) it won't drain the 12v battery. The bigger problem is normally memory card space, if you have a camera recording 24/7 it'll chew through the SD card and may record over something that happens when the car was first parked.
photomac
Post by photomac »
The power on leds are off when car is off. The units use super capacitor storage. I guess very very low power draw. I assume there is a socket in the head unit on the windscreen. The Blackvue doesn’t record when car is off like Tesla Sentry. Day 10 of ownership an incident occurred that the cameras picked up, sound, numberplates and our cabin commentary (I must restrain my language). On the freeway south bound, near Joondalup, A 4WD was trying to overtake on the railway side emergency lane, even putting their wheels into the dirt, while the car in front was in the legal lane doing the limit overtaking the slower left lane.
Yes,   we can.   Image
photomac wrote:
Wed, 11 Sep 2019, 08:30
send it into dashcams australia?
photomac
Post by photomac »
antiscab wrote:
Wed, 11 Sep 2019, 09:46
On reviewing the footage I suspect it is an emergency run, there may be a woman unwell on front passenger seat.
Yes,   we can.   Image
