Page 1 of 1
Kona EV Off Peak Charging
Posted: Tue, 21 May 2019, 08:34
by vk6xre
Hi all, I have a Kona Launch Model. The scheduled off peak charging does not charge within the charging window. I have tried different EVSE units. I have tried setting different times. Nothing. It either charges 7 - 8 pm or refuses to charge at all. Unscheduled charging works fine.
Is anybody else suffering this issue?
Re: Kona EV Off Peak Charging
Posted: Tue, 21 May 2019, 08:40
by g4qber
Tis a bug. Right reecho?
Posted: Thu, 23 May 2019, 15:47
by Clintsc9
I haven't been able to get mine to work either so not worrying about it.
With my electricity supply the difference between peak and off-peak is 4 c/kWh. So a difference of $2.56 on a full charge from empty.
Posted: Fri, 24 May 2019, 18:50
by reecho
Yep. Every Kona worldwide suffers from the issue including mine. Fix in the works. Appears to be a bug in the radio firmware.
https://www.speakev.com/threads/schedul ... ng.138524/
Posted: Tue, 11 Jun 2019, 22:53
by vk6xre
I don't feel it is world wide just the AU and NZ Firmware versions. I have been to my dealer and they tested 2 Konas a Launch Model and a Highlander and they both suffered the same issues.
