Kona EV Off Peak Charging
Hyundai Interest Group
vk6xre
Real Name: Robyn
Post by vk6xre »
Hi all, I have a Kona Launch Model. The scheduled off peak charging does not charge within the charging window. I have tried different EVSE units. I have tried setting different times. Nothing. It either charges 7 - 8 pm or refuses to charge at all. Unscheduled charging works fine.
Is anybody else suffering this issue?
Re: Kona EV Off Peak Charging
Post by g4qber »
Tis a bug. Right reecho?
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 49
Clintsc9
Real Name: Clinton Lovell
Post by Clintsc9 »
I haven't been able to get mine to work either so not worrying about it.
With my electricity supply the difference between peak and off-peak is 4 c/kWh. So a difference of $2.56 on a full charge from empty.
Clint
Post by reecho »
vk6xre wrote: Tue, 21 May 2019, 08:34 Hi all, I have a Kona Launch Model. The scheduled off peak charging does not charge within the charging window. I have tried different EVSE units. I have tried setting different times. Nothing. It either charges 7 - 8 pm or refuses to charge at all. Unscheduled charging works fine.
Yep. Every Kona worldwide suffers from the issue including mine. Fix in the works. Appears to be a bug in the radio firmware.
https://www.speakev.com/threads/schedul ... ng.138524/
vk6xre
Real Name: Robyn
Post by vk6xre »
I don't feel it is world wide just the AU and NZ Firmware versions. I have been to my dealer and they tested 2 Konas a Launch Model and a Highlander and they both suffered the same issues.
vk6xre
Real Name: Robyn
Post by vk6xre »
The bug has been fixed. Go you your favourite dealer and ask for the upgrade to the firmware. It takes 10 minutes. If you are in Perth, I recommend Osbourne Park Hyundai, speak to the Service Manager, Michael, and make a date. He has the firmware for the launch model at least. If it doesn't bother you, it will be updated when your Kona is serviced.
The update on my launch model works 100%. I get into a nice warm car every morning and the car charges at 11pm, in the off peak EV rate time.
Spybo
Post by Spybo »
Thanks for the update :D
ingk
Post by ingk »
Have just been informed by Doncaster Hyundai that a software patch is ready to be installed on my Kona Hylander. To correct charging problems.
They will provide me with a loan car, as they have to contact hyundai when they have the car and it might take a few hours.
Booked in for next Friday..
Have completed 2000km to date and still impressed with the car and the range.
