Single phase charging
- Real Name: David Kerr
Three phase charging of Zoe at 22kW is pretty good. Typically, as long as the SOC is 80% or below, I get 20.7kW into the battery at the DC level. So, 94% or better.
Here are some single phase figures I have just measured on my Zoe at 75% SOC:
Pilot=32A. Actual=32A. Power at meter box=7.6kW. Power at EVSE input=7.35kW. Power to 12V battery=100W. Power to HVbat=6.5kW (377V 17.3A). Efficiency=90%
Pilot=20A. Actual=20A. Power at meter box=4.89kW. Power at EVSE input=4.75kW. Power to 12V battery=60W. Power to HVbat=4.05kW (374.5v 10.8a). Efficiency=86%
Pilot=10A. Actual=9A. Power at meter box=2.12kW. Power at EVSE input=2.04kW. Power to 12V battery=50W. Power to HVbat=1.61kW (375V 4.3A). Efficiency=81%
Pilot=6A. Actual=6A. Power at meter box=1.11W. Power at EVSE input=1.06kW. Power to 12V battery=50W. Power to HVbat=0.56kW (375V 1.5A). Efficiency=55%
Several points:
a. I have corrected for power to the 12V battery. This could be significant at low charging currents if accessories have been in use.
b. If the aircon has to run to cool the battery, you have zero left at 6A as it will use between 500 and 1000W.
c. Powers are measured with a 1% accuracy power meter, so reactance and power factor are taken care of. Power factor is somewhat below 1 between 6 and 10amps
d. If we turn the above figures upside down and calculate how much power we actually need to add 32kW from 0% to 80% SOC we get the following:
32A three phase. 34kWhrs. Wastage=2kWhrs
32A single phase. 35.7kWhrs. Wastage= 3.7kWhrs
20A single phase. 37.2kWhrs. Wastage= 5.2kWhrs.
10A single phase. 39.5kWhrs. Wastage= 7.5kWhrs.
6A single phase. 58.2kWhrs. Wastage = 26.2kWhrs
I did these measurements to see if it was worth my while storing excess solar into a 12kW lithium battery at times when there was not enough excess solar for efficient Zoe charging and then dumping it into Zoe at a constant 20A through a 5kW inverter. This would also allow timeshifting as Zoe is often out when the sun is at its best. It all depends upon the round-trip efficiency of excess-solar->battery->inverter->Zoe and at the moment it looks possibly not worthwhile. Though it would improve the feel-good situation further.....still thinking about it....
Dave
Several points:
Dave
Renault Zoe ZE40, 2017
Re: Single phase charging
There is value in having home storage beyond charging the zoe more efficiently. Do you have time of use power? Not using power in peak periods there's likely to be some savings.
Are you export limited to 5kw? I'd be super tempted to put up more Solar, so there's more time where the surplus is above 6A, and simultaneously set the Zappi to minimum 10A charge and Max import 4A
Hi Matt, I am in a very treed area. So the solar varies a lot with shade hitting panels. That is why I have an Enphase system (which is working well). I already have 5kWhr of Calbs (24V) which I use to flatten out the day and it runs all computers, modems, servers, CCTV etc in the house pretty much 24/7 (we are a very compute-intensive house!) Yes, I can and do set the OpenEVSE to min 10A. I have no limit on the export other than 20c/kWHr for the first 170kWHr/month thence 10c. But I am about to change to someone else with a flat 12.5c/kWhr.
I probably will proceed with the 5kW inverter- I just need to get the right one. I have previously designed and built a 2.8kW unit but would rather not expend the time and energy this time.
Dave
Dave
Hi Dave
As Matt says, it all seems to depend on how much power you have available. At our place, we seem to be blessed with more solar than we actually need. Even after charging a house battery, more than than 1/3 is going back into the grid. It accrues credits that we will probably never get back. This good performance from solar is not due to clever design but totally to happy accident. The part of the roof with the PV panels faces North, the roof slope is greater than 20°, and there is never any shading. It means that we have been able to adopt a fairly lazy attitude to charging Zoe and/or conserving power.
I also agree with Matt that more solar, and possibly more storage is the way to go. Also, if the trees are yours, it is not environmentally irresponsible to prune them a little to reduce shading.
Hi Lou,
Thanks. 60-70 metre Pittwater gums are not easy or cheap to prune!
Hm, I do not think I would like solar credits. We get 20c/kWhr atraight off the power bill.
I am stuck with shade and suboptimal direction (azimuth 70deg, tilt 23deg ). It only became practical & moderately cost effective to install solar last year and then only because of one inverter per panel. Even though a 4.3kW system, solar provided 80% of all power used plus fully charged Zoe (except for 2 interstate trips) over an 8 month period. Most of my electronics run off 24V or 12V and my 5kW 24V battery has proved very effective. We have also exported 600kWHrs since January 1 this year. I have also done a huge amount over the past 5yrs to cut home power usage. I even built my own solar HWS (using 36 evac tubes). Hot water costs me less than $10 per annum. Offpeak boost has been 2.2kW in the past 8 months and that system had paid for itself three years ago.
Anyway, the real purpose of this thread was to give Zoe owners a good feel for the Chameleon charger efficiency. Overall, given it has to cover from 6A 240V to 32A three phase, it does a pretty good job (methinks).
Dave
Dave
I did some charge testing last night. All values are reported by the car, though I did have my clamp meter inside the charge station to do a sanity check on values.
The 3-phase 6A charging looked interesting, I might have to redo that measurement - it looks like the car was actually exporting power in order to observe the current limit.
Meas(A) Pilot AC(kW) AC(kVA) PF Bat(V) Bat(A) Bat(kW) Eff 12v(W) 12v(V) 12v(A) 32.0 32.0 7.35 . . 377 17.3 6.50 90% 100 20.0 20.0 4.75 . . 374.5 10.8 4.05 86% 60 9.0 10.0 2.04 . . 375 4.3 1.61 81% 50 AC (V) 6.0 6.0 1.06 . . 375 1.5 0.56 55% 50 phase3 phase2 phase1 phase3 phase2 phase1 . . . . . . . . . . . 237 9.3 10.0 2.02 2.20 0.92 359.5 4.8 1.73 85% 47 13.3 3.5 238 16.6 16.0 3.69 3.81 0.97 358 9.3 3.33 90% 40 13.4 3 425.5 409 416 15.1 15.4 15.7 16.0 10.28 11.12 0.92 361 26.3 9.49 92% 47 13.3 3.5 428 412 416 12.5 12.7 12.8 13.0 7.93 9.18 0.86 359 20.3 7.29 92% 53 13.3 4 425.5 414 417.5 8.9 9.1 9.3 10.0 5 6.60 0.76 358.5 12.5 4.48 90% 47 13.4 3.5 423.5 419 420 6.1 6.1 6.1 6.0 -0.389 4.45 -0.09 357.5 -0.5 -0.18 46% 53 13.3 4The above table didn't copy from my spreadsheet all that well, so I've attached the original Clearly charging slow is best done on single phase
Hi Matt,
Those figures agree closely with my experience.
However the 6A three phase ones are definitely odd. I'm wondering if the heat pump was running to condition the battery? Heat pump can draw over 3kW and it runs directly off the traction battery.
Since my original post, I did implement two Lithium batteries, both tracking excess solar. I frequently dump the bigger one (8*AVASS 460AH cells) into the Zoe if she has been out during the high insolation part of the day. At 15 to 18A single phase, I get the best result. Inverter efficiency about 91-93% and Zoe charge efficiency about 85%. Battery charge efficiency about 95% depending upon charging current (best 98% at max). I get about 21% into Zoe per charge from the AVASS batteries. I cycle them about 410AH of the notional 460AH.
My system decides to stop charging the batteries if the return drops below what I get from FIT.
I run OpenEVSE at about 18A single phase with minimum 10A if Zoe is home during the day. So OpenEVSE tracks the solar.
Here is a chart showing the excess solar tracking using my two chargers and lithium batteries. Yellow is solar input. Blue is usage. Usage in this case was breadmaker, fridge, waterbed, making coffee, all computers etc etc. The first battery is 8*CALB180 and charges from 2 up to 38amps. When there is excess solar beyond that plus other usage, the second one kicks in. It does 2 to 58A. Also, the first battery automatically kicks in to supply all my computers, switches, modems, 8CCTV cameras, servers etc. So typically they run off the battery until there is enough sun, then they switch back to mains power and then when the insolation increases, the first charger kicks in. All the computer gear runs off 24V and I pensioned off over three dozen power adaptors.
- Attachments
- Screenshot from 2019-10-19 16-43-56.png (42.64 KiB) Viewed 2120 times
Does it do that standard, or did you have to write some of your own software?
OpenEVSE needs no extra software. As standard it can track extra solar. However, I did need to write a Python script which extracts data from the Enphase Envoy (controller for the microInverters) and make it available through MQTT.
I DID have to write heaps of software for my two lithium chargers, BMSs etc.
Dave
Dave
What did you load the python script into?
The python script runs on a reliable low power Linux server which also hosts my email, file storage for the house, CCTV footage etc. This server runs on 12V using OpenUPS power supplies and a low power Motherboard/CPU and ZFS disk array. However, the python script could run on anything as I also have a number of Odroids and Beaglebone Blacks around the place any of which would be fine. The latter run things like my Weather Station, Media Servers, Backups of the Backups.... The Python script is an undemanding chunk of code which runs every 10secs....Thus OpenEVSE and also my two Lithium systems run on the same MQTT data which is posted every 10 seconds. This system runs very reliably for at least a year at a time without needing to be rebooted.
Incidentally, the two Lithium chargers/controllers are PIC based each having one overall PIC controller and a dedicated PIC driving each Buck Converter. I use an Onion Omega2 to provide the user interface because they are powerful, cheap as dirt, reliable and have WiFi and direct Ethernet. However, I only use the WiFi and they talk to the PICs via serial. So my Lithium chargers are online and I can access them from anywhere in the world.
Overall, the python script was first and I needed that so that OpenEVSE could track excess solar. Then when I decided to build the first Lithium battery and control/BMS stuff, that project grew bigger and bigger and consumed a lot of time and effort. The second, bigger Lithium setup was way quicker and I only did it because I had the good fortune to buy 8 AVASS cells. I was able to reuse all the previous effort.
So now, it is all finished. It would have been nice to have all this integrated into a new-build house, but I have had to make do with a 40yr old house and things grafted into it rather than having a master ATS on the switchboard and the ability to run the whole house on the big battery. Instead, I use the big battery for EV charging, running Aircons and as a backup when the Grid fails (as it does more often). 5kVA (15kVA peak) is enough to run the garage, microwave, kettle, some lighting, aircon, EV charging. But I have to manually switch things over when the grid fails.
The smaller battery is running all the IT stuff and does this from Solar for a very large percentage of the year (it is prioritised over the AVASS battery). It is all automated (i.e. it decides when to switch to battery power, when to switch off from battery to mains, when to charge and the tracking.
Dave
Dave
Hi All,
As part of a research program at uni I'm working on creating a EV charger controller that takes multiple inputs and determines the best way to charge the connected electric vehicle while efficiently utilising the network grid connected (ie. avoid peak time charging if possible, utilise excess solar, etc).
I'm after some usage data (pre-COVID-19 preferably) from an energy meter of residential and commercial properties with an EV charger in the SE QLD region to conduct some modelling tests.
Appreciate any help you can provide.
Dave
Dave
- jonescg
- Real Name: Chris Jones
Sounds great - how will it differ from the Zappi charger then?
Or EO for that matter.
Dave are you planning on building a unit? Or just modelling one? If the former, I would be happy to act as a guinea pig
- g4qber
- Real Name: Joseph
Lakeside Joondalup Cinemas
104 McLarty Ave, Joondalup WA 6027, Australia
https://www.plugshare.com/location/127624
This Zoe doesn’t like the ground connection at Joondalup.
Need more Zoes to test if it is just this ex-Esperance Zoe that couldn’t charge at 3phase down at Ravensthorpe.
- jonescg
*Frenchmans spit*
I doonot like this po-wer!
- Bryce
- Real Name: Bryce Gaton
Current EV drive: 2019 Kona electric
the problem is too much coal in the electricity...........France does not have any now......Zoe knows this.........
I've had one three phase 22KVA EVSE which will not charge. It's at a nearby shopping centre and there are two Tesla DCs. The left hand one sometimes works (about 1 in 3) and the other one always works. The problem is poor neutral-ground bond on the left hand one. Can be checked using CanZE on the Zoe. A second Zoe has exactly the same experience. Teslas have no problem with the left hand outlet. The owner of the business is not inclined to do anything about it.
The Zoe does a lot of bonding checks and also does checks of high frequency as well as low frequency leakage and also DC leakage. As such, it is undoubtedly more sensitive that some other cars & does more checks but it needs to be because of the way the charger uses the motor windings.
I've also run into some suspect three phase outlets at camp grounds and fortunately have an independent RCD in the OpenEVSE.
Dave
Dave
I have been having some issues with charging my Zoe. We have the Schneider EV Link single phase wall charger. It starts off fine, but when I check a few hours later it has stopped charging and is doing checks. Today I started charging at 19% and when I returned it had stopped at 55%. Last charge, it stopped at 80%. Once I open the door and the dash comes on, it starts charging again. We also have a 2012 ZEO Leaf, which we set to an 80% charge, but there doesn't seem to be the facility to do this on the Zoe.
I have looked for some info. about this, and this thread seems to be the closest I can find. Apart from that, love the car and all is well.
Any guidance would be greatly appreciated.
2019 Renault Zoe
2012 Nissan Leaf
2000 Daihatsu Sirion conversion (deceased)
2012 Nissan Leaf
This is not something I have experienced.
You could perhaps check overseas forums.
If you can lay your hands on another EVSE it would be worth a try.
If it is doing checks, it implies it might not be seeing the right information from the Pilot connection.
There are a couple of things you can programme such as start and stop time in the car. Make sure these are off. But from your description that sounds unlikely.
Just hope it is not a fault that has developed internally. Mine stopped charging totally earlier this year and I was off the road for a long time (see elsewhere in the forum for gory details).
Regds,
Dave
Regds,
Dave
- Bryce
Hi there - seems to be an issue with Zoes and some EVSEs. (Had the same happen with ours on my wall EVSE - the Zoe randomly stops charging. A reset of the EVSE off/on again sets it right again). Am in the process of swapping the EVSE over to another. Will report back once that's done.
Bryce
Bryce
Thanks for your advice.
The Zoe eventually charged to 100%, so all good for now.
I have checked the charge timer and that has not been set.
Initially, I left the charger on between charges, but now I turn it off at the wall.
I have charged it twice at a public charger outside our local Bunnings, and it works fine. I would be surprised if the Schneider (through Jet Charge) is causing problems, but it seems from some of the posts on here that the Zoe can be a bit finicky.
I will keep you posted.
2019 Renault Zoe
2012 Nissan Leaf
2012 Nissan Leaf
Good to hear it is working.
Zoe does a lot of checks such as DC and LF and HF leakage tests. It also tests neutral to ground resistance. However, if there is a problem with these, you should normally get a red coloured message about checking the charging post.
If you get a suitable BT dongle (about $20) and the free app CanZE, you can see a lot of these things yourself. But first I would try another EVSE and if still having problems check using CanZE. If the ground neutral resistance is a problem, you would need to get an electrician to take a look at your house wiring. If you had high leakage, that could be a range of things depending upon what you see.
Regds,
Dave
Regds,
Dave
