Has anyone else had a problem with the spray nozzles on the wiper arm?
The inner drivers one has never done it’s job and I’ve tried ‘unblocking with the pin’ trick to no avail.
Is mine a one-off?
Wiper spray nozzle issue
- Real Name: Rod
Re: Wiper spray nozzle issue
You can book a service using the cars UI.
It should be covered under warranty.
Yeah, it’s 130 km away in Richmond and I don’t want to hassle them if I can simply adjust it (water flows from it but I’ll need to fiddle with it more.....the nozzle is very stiff)
