As a backup power source ?
Tesla EVs Interest Group
Nagaman
Real Name: David
Post by Nagaman »
Apparently the Leaf can do house power backup so is that something to look forward to with Tesla?.
We have have serious power disruptions approximately twice a year and never get so much as an offer of compensation for lost food resulting.
Not happy.
Re: As a backup power source ?
Tesla owners practically live in their cars, so they're killing two birds with one stone :D
Leafs have chademo which is bi directional. Teslas don't have chademo so I wouldn't expect it any time soon. Also Elon Musk said a few years back that teslas won't have car to grid. I'd guess the argument is he wants to sell you a power wall
Post by reecho »
Nagaman wrote: Fri, 29 Nov 2019, 11:57 Apparently the Leaf can do house power backup so is that something to look forward to with Tesla?.
Not happy.
As a rule no. CCS protocol doesn't include VTH or VTG capability right now, but it will be included in the future.
pmacgowan
Real Name: Paul Macgowan
Post by pmacgowan »
For emergency power, I wanted to put a 1000w inverter directly of the model3 battery. I was thinking about putting a 120amp x 40cm (with 100amp fuse) wire to a surface mounted 100amp anderson plug located in the frunk. I could then put the car in neutral and run the inverter.
From my research:
https://www.youtube.com/watch?v=XikJPXSSHOI
I believe the DC to DC inverter in the model 3 should be able to supply at least 1.5kw (to 12v battery) safely.
I did the same for my older 2008 prius and it worked like a charm, could keep the fridge + other essentials going in an emergency.
It seems silly that I have a massive 50kw battery that I cannot use for emergency power.
Can anyone see any flaws in my approach????
Post by reecho »
pmacgowan wrote: Sat, 30 Nov 2019, 12:10 For emergency power, I wanted to put a 1000w inverter directly of the model3 battery. I was thinking about putting a 120amp x 40cm (with 100amp fuse) wire to a surface mounted 100amp anderson plug located in the frunk. I could then put the car in neutral and run the inverter.
No. Been done with the Kona Electric already. Having a selectable Utility Mode makes it workable...
https://pmarks.net/konapower/
pmacgowan
Post by pmacgowan »
Thanks, thats what I wanted to do with the M3
Nagaman
Real Name: David
Post by Nagaman »
I’m assuming this Plug Life Television isn’t new to the majority, but for some truly interested in electro chemistry who haven’t stumbled across it, I consider it number uno :
https://youtu.be/J_Z0QlVs7cs
(......and get some life into this forum also)
