The 3 is 140 mm apparently but I assume the Y will be significantly greater.
Does anyone have any info on it in the sense of basic dimensions?.
1 - 2 months means sometime in January for the first ones off the line.......according to HyperChange.
Model Y ground clearance
- jonescg
- Real Name: Chris Jones
Re: Model Y ground clearance
It would probably depend on the wheels to some extent. A set of 18"s would help.
