Leinster Adventure - 886/888 kms in an i3 REx
BMW i3 discussion forum
886 km one way
888 km from Leinster to UWA Fast Charger
one observation is that battery is used up even in hold mode.
The REx can only be turned on when battery is at 75% charge.
https://www.facebook.com/media/set/?set ... f28bab7b3b
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 20
KLE has since been upgraded. now can charge at 7.2kW
need to do another petrol based road trip to see if the battery is depleted when using Hold mode.
