Replacement key
rkeech
Real Name: Richard Keech
Replacement key
Post by rkeech »
Any idea if the Blade Electron still has the original Getz ECU on board to allow it to be programmed to accept new keys?
Refer http://www.justanswer.com/australia-car ... cking.html
If it doesn't have the ECU, then any ideas how the alarm can be permanently disabled so that I can use the a replacement key without the radio transmitter?
