front plate holder for small custom plate
Volt Interest Group
rkeech
Real Name: Richard Keech
Post by rkeech »
hi,
I want some advice in mounting a small custom front plate on a Volt.
The front plate holder is 350mm x 110mm. My plate is 250mm x 100mm.
A full-size plate is 370mm x 130mm.
When my plate is mounted there is a lot of the grey plastic holder showing which is unsightly.
Does anyone know how the front plate holder is fixed to the bumper? There are no screws.
I figure my options are either:
a. modify the existing plate holder; or
b. make a custom plate holder; or
c. put a small crease in the plate and fit conformal to the bumper.
Any thoughts?
