PHEV Loss of Km Range with Battery.
Re: PHEV Loss of Km Range with Battery.
I’m currently in discussions with MMA re battery in a less than 5 year old from sale 2014 model PHEV with less than 90k km travelled that has battery at dealer confirmed more than 30% SOH degradation. Awaiting further response from MMA thus far but keen to hear from others with this experience how it went for them (J Cooper we have connected with each other on this already recently and nothing new to comment from my experience yet).
I'm in a similar position and I would appreciate any advice you can offer about who to contact at MMA and the best order in which to do things.
I'm currently in WA but will be moving to VIC in a few weeks.
Rolf
Rolf
Hello,
We have been trying to negotiate this with MMA since November last year with no resolution, most recently I have involved our state office of fair trading and MMA are still denying any claim that there is a problem and that battery degradation of 37% is normal. I have provided the old website information, and explained that this level of drop is almost double what was expected when we purchased it second hand in 2017. They aren't budging, if anyone has had recent success I would really appreciate assistance with the wording and the best way to approach this. The office of fair trading has suggested we take it to QCAT (the independent tribunal in Qld), I'm still deciding how best to proceed. I certainly would not have purchased this car if I had known how quickly the battery would fail.
I have now contacted MMA and indicated that the battery degradation was excessive. They responded that it was normal and that the battery needed to be tested by a dealer. This was done this week with the result showing that it was down to about 64% after less than 50,000 EVkms. This is clearly not the 20% loss over 10 years. This is also a clear indication that either the battery was manufactured from sub standard materials or that the BMS has ruined the battery. Either way the fault has to lie with Mitsubishi for designing a car that failed.
It does not matter if he degradation was due to the BMS overcharging or over-discharging the battery as these parameters are set by Mitsubishi.
It does not matter if the battery was damaged by high temperatures as Mitsubishi designed the cooling system.
I have worked with batteries of many chemistries for decades and I can tell you that for example with LIFEPO4 a good quality battery will deliver between 2000 and 5000 cycles at 80% DOD before it loses 20% of it's capacity. My PHEV battery has had only 1000 charge cycles and it is already below 65%.
I can understand that MMA are running a business and that they want to maximize their profit and minimize their expenses.
But, the average life expectancy of most cars is close to 20 years and even then the fuel consumption and features should be close to new.
If the Outlander PHEV only has a useful life of 5 years an a PHEV and then becomes just a HEV the extra weight of he battery now increases fuel consumption.
When you consider the manufacturing energy cost this vehicle needs to operate for about 7 years to offset it's initial extra carbon emissions when compared to an equivalent combustion engine vehicle. I think that if Mitsubishi care about the environment and have any intent to deliver a vehicle that results in a better outcome for the planet, they have no choice but to replace batteries that have degraded to the point where they make the vehicle unusable as a PHEV.
I appreciate that Mitsubishi were one of the first to produce a PHEV that was widely available, I also appreciate that they took a risk in leading the market as there were unknowns regarding battery life, however this risk was taken by a massive corporation, not by the current owners of the vehicle.
All manner of EVs and battery storage systems have proved beyond any doubt that the lithium chemistry is capable of at least 2000 charge cycles before there is more than 20% degradation, if these batteries show more than that then they are defective.
I will continue to push for MMA to do the right thing by replacing the battery, I can only hope that the new batteries or BMUs have software improvements that result in a better life.
If the short life is due to inadequate cooling or demanding too much power from the pack then the issue is likely to re-occur.
I think Mitsubishi produced a great vehicle and I think they got many things right. I believe that they will do the right thing and rectify these issues.
I will keep pushing MMA for a resolution to the issue and continue to escalate it as necessary.
Many owners in Australia have had their batteries replaced once they demonstrate an unreasonable loss of capacity, I think MMA should prefer to deal with each owner on a case by case basis.
However if they start refusing to cooperate the next option would be a class action by owners. This would result in tremendous bad PR for MMA and they would be be in a worse position at the end of it, I don't believe they would choose this path.
I'm happy to discuss this with anyone, PM me for my email address.
They've obviously decided that stonewalling is going to be their new approach. I've yet to start down this path, and my 2014.5 vehicle is low-use with battery only just under 80% anyway, but will be watching with interest. A serious class action threat may well do wonders, but would take some organising, particularly as most owners will have no idea that there is even an issue.
- zzcoopej
- Real Name: Jeremy
It sounds like staff changes may have altered the MMAL response to battery warranty claims. Don't give up.live2fly wrote: ↑Sat, 13 Feb 2021, 18:00 But, the average life expectancy of most cars is close to 20 years and even then the fuel consumption and features should be close to new.
I have a copy of a letter from MMAL (referenced in the "Unplugged EV" uTube channel) to do with the warranty battery replacements which states -
"For the avoidance of doubt MMAL considers the life of a vehicle to be ten years".
This relates to the original claim on the PHEV website that -
"The battery is not a service item which is expected to need replacement during the vehicle's life ...."
Are you dealing with MMAL in Adelaide either by email or letter so you have a documented history of discussion?
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
2015 PHEV Aspire
www.EvPositive.com
Yes, I am dealing with MMAL in Adelaide.
As they put Private and Confidential into the email message I won't copy and paste it here, but I can summaries their points.
Their current website contains a disclaimer that the battery is not a service item, that it degrades over time, that degradation is normal for batteries and that it does not affect the use of the vehicle (beyond making it pointless to own as an PHEV).
Their current website does not state that the vehicle would operate like new for 10 years.
There is no evidence of a manufacturing defect and so there is no possible claim.
Obviously I can't agree with any of these points.
What is on the current website is irrelevant, that was on their website then the vehicle was initially sold is the only important thing.
A precedent has been set, not just in Australia, but globally for batteries to be replaced if they degrade to the point where they are no longer able to provide 80% of the design range of the vehicle within the first 10 years.
As I mentioned before the life of this battery depends on how it is treated, 2000 cycles @ 80% DOD is normal for this battery chemistry. Having nearly 40% loss after just 1000 cycles is not.
They mention Temperature and charging equipment as reasons for degradation, but again I have to point out that the BMU and BMS is responsible for looking after the battery, it will limit charge and discharge current to levels set by the manufacturer. In the same way the BMS will limit use based on temperature to protect the battery. If the BMS has failed to protect the battery it can only be due to the manufacturer having programmed it with incorrect parameters.
You can't blame a customer for driving a car in the way it was advertised or for charging it with the supplied charger.
I totally understand that it would be unreasonable not to expect deterioration from a 10 year old car or a car that has done 200,000kms. But to lose 40% of the battery capacity in the first 5 years and 50,000kms is clearly not reasonable degradation.
I will keep pushing back with these arguments.
I think the manufacturer needs to look at vehicles on a case by case basis, and take into account the age and mileage of each vehicle, this still gives them some control over the process and limits them to only replacing batteries that have degraded significantly.
But I am quite serious that if they absolutely refuse to be reasonable a class action would be the next option.
- zzcoopej
- Real Name: Jeremy
Is this the same wording as you received? If so, nothing has changed.
Thank you for your concern regarding reduced EV range in your vehicle.
Due to the nature of rechargeable lithium-ion batteries, it is normal to experience a gradual reduction in drive battery capacity over time. This does not necessarily indicate a manufacturing concern with the battery, but more a gradual change in the lithium-ion battery’s internal chemical composition. The rate at which this degradation occurs is based on the usage conditions, storage conditions, and charge/discharge cycles experienced by the battery.
There are two main types of degradation – Cyclic Degradation (degradation due to discharge/charge) and Calendar Degradation (degradation due to time). Factors that accelerate cyclic degradation are high discharge/charge rates, high energy demands at high/low battery state of charge, and complete battery discharge situations. Factors that accelerate calendar degradation are amount of time in service, high ambient temperatures in storage (when the vehicle is not in use) and high battery state of charge when in storage.
Degradation occurs when the Solid Electrolyte Interface (SEI - a thin layer formed between the battery electrodes and battery electrolyte) grows due to normal electron transfer within the battery (during discharge or charging operations). As this SEI increases in size, it not only inhibits electron flow within the battery, but the growth itself is due to the SEI consuming some of the battery’s active materials (reducing capacity and performance).
When calculating battery degradation, the remaining capacity of the battery recorded in the Battery Monitoring Unit (BMU), with the EV battery at full charge, is compared to the new battery capacity amount. As EV range estimation (in the combination meter) is continually changing depending on driving history, it cannot be used to accurately determine degradation or remaining battery capacity.
As the vehicle’s EV battery is monitored by a Battery Monitoring Unit (BMU), any abnormal degradation of individual cells will be identified by the BMU and a warning light illuminated to alert the driver to a concern with the EV battery system. Degradation that occurs evenly across the EV battery cells is considered normal. As such, it will not be indicated as a concern by the BMU and does not indicate a manufacturing defect.
As the cause of this concern is not considered a manufacturing defect, replacement of the battery is not covered under the terms and conditions of the manufacturer’s warranty.
We understand your concerns and take them seriously, as such, the first step is to have an authorised Mitsubishi PHEV dealer provide a BMU data snapshot to confirm the level of degradation.
Please let us know when the vehicle is booked in so we can contact the Service Manager.
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
2015 PHEV Aspire
www.EvPositive.com
That was the first response, the second one is different wording.
Yes, we also received the same response initially and they then gave another one when pushed by the qld office of fair trade
HI all,
Just wondering if there has been any more success in 2021. I just got my BMS report from Mitsubishi Melville in Perth during our scheduled service and as suspected the 'Battery current capacity' is 27.3Ah (and 'Battery remaining capacity is 19.1Ah - is that just because it isn't fully charged at testing time?)
I plan to contact Mitsubishi and request repair under Australian consumer law provisions (warranty expired last year). Keen to hear any tips on recent successes. Cheers, James
- zzcoopej
- Real Name: Jeremy
I've actually heard the opposite, there is an Australian Facebook page where a guy is having no luck getting his battery replaced, so it looks like MMAL have changed their tune since I had mine done.
That's about 72% of new, enough for a claim if you purchased at the time of the original website claim. (This is the SOH value)
Correct, that's just the charge at the time of testing (SOC value)
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
2015 PHEV Aspire
www.EvPositive.com
I’ve had a bit of back and forth discussion with Mitsubishi with varying stonewalling responses from them but last response was “we’ve ordered a new battery as gesture of goodwill”!!!
Said it will take some time to arrive.
- zzcoopej
- Real Name: Jeremy
Well done! Yes they do take a month or 2 to be shipped to Oz, and that was pre-covid....
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
2015 PHEV Aspire
www.EvPositive.com
After months of backwards and forwards with MMAL they have finally refused to rectify the battery in our vehicle. PHEV watchdog reports it as being down to 58.7% capacity.
The final response from MMAL is:
I have given them 1 week to reconsider their decision but after that I will be organizing a class action against MMAL and also commencing a campaign highlighting the issues with MMAL and this particular vehicle.
I really can't believe that a large company like MMAL would want negative publicity or that they are refusing to honor their promises, but here we are.
Once I get the website up detailing the issues with the vehicle and the registration forms for joining the class action I will post them here.
One of the crazy things about class action in Australia that I found out from talking to a lawyer is that it is we have an opt out model here. That means that to start a no win, no fee suit against MMAL I just need 6 other people with vehicles in the same situation. Then once the case proceeds any other owner in the same position is automatically included included.
The cost to MMAL in bad publicity and damages from potentially hundreds or thousands of claims far outweighs a battery replacement, but it appears that they have run out of good will.
As MMAL are clearly not honoring the promises they made at the time of sale of the vehicle I have no choice but to commence action against them.As previously advised, the battery is not a service item which is expected to need replacement during the vehicle's life and replacement is not included in your PHEV's maintenance schedule.
There will be some natural degradation of the Lithium-ion battery chemistry over the life of the vehicle which will lead to a reduction in the pure EV range of your PHEV. The capacity of Lithium-ion batteries generally decreases over time due to a range of factors including, but not limited to: operating environment, temperature, storage, charging frequency and/or equipment used, and battery usage. This decrease is an inherent characteristic of Lithium-ion batteries, and is not due to failure or a manufacturing defects.
As there is no evidence of a manufacturing defect, Mitsubishi Motors Australia Limited (MMAL) will not be providing a replacement battery.
- zzcoopej
- Real Name: Jeremy
That's no good. Have you compared your correspondence and PHEV model with Jimbob as he recently had the opposite outcome?
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
2015 PHEV Aspire
www.EvPositive.com
I tried to PM Jimbob after he made his post but he has not responded.
My experience with Customer relations has been very poor, they have alternated between failing to respond to emails and repeating that the battery is not a service item and the car works fine using the ICE so the battery condition is irrelevant.
Quite frankly calling the department Customer Relations seems like a bit of a joke, at this point I'm annoyed enough to be prepared to spend a lot of my own time and money in order to pressure MMAL into doing the right thing.
They have not been open about what exactly their decision making criteria are, but I believe the following is correct.
- There is no question that they know the battery capacity of our vehicle is currently around 60% of original.
They say that as they changed their website to remove their original promises about the life of the battery those promises no longer exist.
They say that the warranty is not attached to the vehicle, it is attached to the original purchaser. If you purchase a second hand Mitsubishi any warranty claim would only be honored because of their good will.
They have been very careful to never admit rectifying any fault with the cars or batteries and to claim it is just that they are just showing good will when they replace a battery.
In reality it seems that in order to get them to honor their promises and warranty you have to exert enough pressure on them to make them offer you good will.
I suspect it may be because we are recent owners of this vehicle and it was purchased privately. Probably if there was a dealer involved and he was exerting pressure on MMAL they might feel more good will.
- Noobie
Sorry if I missed this in earlier discussion, but is there any sign battery is improving in more recent model years? That is, have they fixed the problem in new models?
Hi All,
I have a 2014 Outlander PHEV that only has 25km range after a full charge. I am very interested in how this all pans out.
- Johny
- Real Name: John Wright
I guess it'll be a couple of years before we know but there have not been any press releases from Mitsu indicating battery improvements other than slightly more capacity.Brucellosis wrote: ↑Sun, 30 May 2021, 18:03 Sorry if I missed this in earlier discussion, but is there any sign battery is improving in more recent model years? That is, have they fixed the problem in new models?
Hi All,
Sadly after taking the vehicle into a Mitsubishi dealer again MMAL are still stonewalling regarding the battery. Their latest response is shown below:
MMAL have sold a vehicle that has an effective battery life of about 5 years as being good for the environment. Once you take into account the average lifetime emissions and the energy required to produce the battery the Outlander PHEV scores worse than a diesel. The annoying thing is we bought this car for considerably more than the diesel version because of the promises from Mitsubishi about low fuel consumption and battery/drive-train lifetime. We bought it to make a statement that we care about the environment and want to minimise our impact and we have ended up with an inefficient petrol car that has hundreds of kg of kg of useless battery on board.
My advice to everyone is not to deal with MMAL and to avoid the Mitsubishi brand in Australia completely. Elsewhere in the world Mitsubishi is doing the right thing so the fault here lies entirely with MMAL.
I'm still looking to mount a class action, so if there are others out there who have been abandoned by MMAL get in touch.
It appears that if you are not the first owner of a vehicle MMAL will no longer honor their promises or the vehicle warranty.Your case has been reviewed by Mitsubishi Motors Australia Limited (MMAL) Corporate Management and our decision remains unchanged.
The information you are quoting was not on the Mitsubishi website at the time you purchased the above vehicle.
Battery degradation is normal, it is not considered a manufacturing defect and replacement of the battery is not covered under the Terms and Conditions of the manufacturer’s warranty.
- brendon_m
- Real Name: Brendon McCarrol
I assume you have spoken to consumer affairs? If not they might be the catalyst to make MMAL move.
- Real Name: Richard
Glad I got rid of mine.
I don't think the issue is with the cells themselves, but a poor CMU and BMU hardware and firmware implementation artificially reducing the capacity of the pack over time. The I-Miev I owned prior is the same.
And with a 12kWh pack onboard and only using 8kWh of that to 0% SOC it isn't a full cycle by any marker. They could go deeper and they should.
- jonescg
- Real Name: Chris Jones
At least @rhills managed to keep most of the cells from his Outlander. Would be curious to see how their capacity stands up.
AEVA National President, returning WA branch chair.
Would like to get in touch about this action. Mine is just 12 months old and already down to 79%. I'm already getting the identical brush off from MMA.
live2fly wrote: ↑Thu, 01 Jul 2021, 14:38 Hi All,
