Battery life
Battery life
Just had a query from prospective owner in Queensland about batt life in warm to hot areas
Via Glenn pitcher paceway
I suggested 10 years at first then said 8 years
Also mentioned 5 year aus warranty
And batt is cooled with ac when on fast charge
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 20
Malm
Battery life
Post by Malm »
I would say the same. It can be worst (only 6 or 7 years) or better. We just don't know. But it depends on the distance that we need to do everyday (or if we can charge at work).
zzcoopej
Real Name: Jeremy
Battery life
Post by zzcoopej »
I think I've read somewhere (can't find it again however) that its best to run the battery down low before recharging it. Is that correct, and where is the definitive list of do's and don'ts?
The problem I have with running the battery down low, is that you need to plan ahead whether you're going to do more than X km the next day (I charge overnight on offpeak tariff). Normal day use is about 30km so 2-3 days before charging, but by the 3rd day there is not much flexibility for a change in plans.
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
Real Name: Richard Baird
Battery life
Post by reecho »
Rule of thumb...
1) Don't leave fully charged for any length of time.
2) Don't leave completely discharged for any length of time.
3) Avoid overheating the batteries when parked.
4) Charge whenever you like and enjoy...!!
LauraiMiEV
Real Name: Laura
Battery life
Post by LauraiMiEV »
zzcoopej wrote: I think I've read somewhere (can't find it again however) that its best to run the battery down low before recharging it. Is that correct, and where is the definitive list of do's and don'ts?
I can't find the "definitive list" but this article (and I'm sure many others) http://www.carshowroom.com.au/newcars/n ... Mitsubishi mentions that the memory function we all used to be terrified of with our mobile phones isn't a problem with the iMiEV batteries so you can top up even if it's low.
I have read (can't find the reference) that there is a problem with parking an iMiEV for long periods (one assumes weeks, not days) with a full charge or sitting on a trickle charge. This can/does limit battery function. This is what worries me since I just bought a "new" 2012 iMiEV which was sitting somewhere for 2 years and I can't imagine anyone drained and topped up the battery every few weeks. But so far so good. I can go 130 km easily and get home with 2 bars left.
LauraiMiEV
Real Name: Laura
Battery life
As an aside, this Wikipedia page warns about charging outside of 0-45 degrees C. Can cause battery damage so depending on time of year and where you live you may want to watch out for this.
http://en.wikipedia.org/wiki/Lithium-io ... mperatures
Battery life
If you can do 130km with 2 bars remaining. Two bars is 22% SOC. Then your back is very healthyImage
The word (trickle charging)or a constant low output charge if the charger remains on doesn't apply to our Imiev's and there lithium battery charger. If you place the car on charge and walk away. The charger charges the batterys to 100% SOC several hrs then it switches off completely.
When storing the car as long as they battery is some where around 1/2 charged then everything is fine. My personal rule is having the battery at 100% SOC for more than a few hrs is not a good thing and having the battery at 100% SOC and in a hot environment for any length of time is a very bad thing.
I keep my imiev stored in the garage under the house cool - dark area about at about 40% soc if I'm not using it. That said we just use the car and if a hot car park is a unavoidable situation then so be it but when avoidable why not treat it nice.
Worst case scenario is car with a battery at 100% SOC and car parked out in the summer sun for days - weeks.
Battery life
Malm do you have cells with voltages this low?
3.465V
Greg partridge
Real Name: Greg partridge
Battery life
Post by Greg partridge »
g4qber how do you get these graphics on your i MiEV? I would like to be able to check out my cells
Battery life
Post by reecho »
The software used for the diagnostic screens is Canion
So you need an android device either a phone or tablet.
The other item you need is a bluetooth dongle
Malm
Battery life
Post by Malm »
g4qber wrote: Image
3.465V
First of all, I think 100% SoC is not the same amount of energy in different I-MiEV. In some (the new ones) I believe 100% is 16 kWh in the battery. But in mine, now, 100% SoC is less energy, I believe between 13 and 14 kWh.
Peter C in Canberra
Real Name: Peter Campbell
Battery life
Post by Peter C in Canberra »
The dreaded 'memory effect' is only an issue for NiCd batteries and that is not what we have. Occasionally (every few months) running the battery to less than 2 bars is recommended but it seems to only be for resetting the battery monitoring electronics. Same thing for your laptop battery. They only say to run that to near flat occasionally to make the battery gauge more accurate. Just charge when it suits you. If you have time-of-use electricity metering, use a timer to charge on cheaper off-peak, unless you expect to need the battery full sooner.
Battery life
Ian R's 2010 imiev without 5th Pin
at 16000 kms
doing the math
100/33.5 * 28 = 83 km range.
Comet
Real Name: Haeley Reeves
Battery life
Post by Comet »
Anyone in Brisbane area with this kit?
Had my I-miev one week and learning all the tech stuff.
Would love to know the condition of my batteries.
I-miev it in MY10 with extras!
Battery life
Hi Comet,
        I am in Brisbane weekdays and have the Canion app and obd scanner. You welcome to PM me to work something out. Or Wednesday 18th Feb at 7:30pm is out next AEVA meting. worth coming along.
