Not sure what others have done but here is one idea that seems simple to implement, will allow easy cleaning, will keeps stone away from the condenser and not change air flow to any degree. I also pull some of the front body panels off (behind the moulded bumper) to see if an easier more obvious mounting arrangement could be added but no such luck. But maybe someone else can see an easier solution?
So I’m open to suggestions.... Please note this is prototype 1 – it will have a small “U” section rubber edging fitted and will be secured with four small “L” brackets using ‘NutSerts’ (or whatever name you like to call them). This will allow the mesh to be removed easily. See the bottom photos for details of this.
Unmodified
The template – ‘A’ rests on the little lip and ‘B’ slots up behind neatly
The template fitted
316 SS mesh cut to template size
About 14 wires per inch - .6mm dia. wire used (ONLY because I have a roll) - nice mix of units here!
Sample fit
Small profile rubber 'U' shaped edging will be used to prevent scratching of the paint work and cutting fingers.
Will end up looking like this....
Mesh will be secured via 4 SS screws to 4 small satin black 'L' brackets using a NutSert tool for captive nut fastening. I think the mesh will be left unpainted in our case....
Anyway it sort of suits the front appearance of the i, I have some intercooler mesh from a modified WRX turbo frontend but it really looks out of place given the car is so small.
Now for the first i-MiEV question of 2014:
What is the little thingy for on the right side of the A/C condenser air intake channel??
Bruce
