This was mentioned a long time ago (https://forums.aeva.asn.au/viewtopic.ph ... rut#p61903) but I only recently found about this issue through a reddit discussion where someone's strut became detached because of rust.
One suggestion was to open up the access ports above the struts and insert protective plastic caps.
Reddit thread (with links to youtube videos is...
https://www.reddit.com/r/leaf/comments/ ... lure_rust/
eBay search for an appropriate part is...
Front Top Suspension Strut Mount Cover Cap 54330 ED000
I've ordered a couple of these ($4 - 5 from China, $12 - 15 sources in Aus); in the interim I've placed a take away food container over the strut to stop further water getting in.
Rust in strut tower (reprise)
Re: Rust in strut tower (reprise)
I used a couple of lids, supplied for free with my Aldi coffee. siliconed in place. The colour matches the bronze colour of the car, and the coffee stopped me being bad tempered.
There was a comment from the male party about "I hope you never want to change these shock absorbers"
2017 Leaf 30kWh battery
2nd hand Japanese import
Solar powered as much as practical
Image link doesn't seem to have loaded the image
You need to know which coffee to buy
https://imgur.com/a/GJzxXto
For successful posting, you also need to know how to dig out the URL to the actual image:
There used to be peaches you could buy, but they changed the size.
OK, will try again another time.
