New EV project
For Queensland Members of the AEVA
Electron
New EV project
Post by Electron »
Had an interestering discussion last night about the 4WD EV conversion.
Firstly the vehicle will be built initally as a daily driver and when finished and tested, planning for a desert crossing for mid 2011 will begin.
The following basic decisions were made.
The series 11 landrover is suitable for the conversion, light weight and strong chassis, no vacuum brakes or demister.
Drive motor will be a 12kw series unit running on 144v. The motor will be fitted to the existing gearbox, the clutch will be retained as well as the rest of the transmission.
Batteries will initally be lead acid with the possibility of lithium in the future. battery boxes will be fitted on the outside of the chassis between the front and rear wheels and inside the chassis either side of the rear tailshaft. If necessary batteries could be mounted in the engine bay.
Battery charger will be on board, to allow for oppintunity charging.
The next stage is to source the electric motor and manufacture an adapator plate to fit the motor to the gear box.
Ron
dko
Real Name: Stefano Ruggeri
New EV project
Post by dko »
Ron,
compliments for the positive meeting !
If you make a technical drawing for the adapter plate, I can make it.
I need a drawing in DWG or DXF format.
Ciao Stefano
Shaggy
New EV project
Post by Shaggy »
Ron,
Thanks for your efforts on Wednesday night. Thanks also to everyone for their participation and comments on the build. There was a lot of good ideas and kind offers of help.
I'm still considering the generous offer of some help with using a suzuki gearbox for the build from Suzi Auto Services. Whilst there would be some fannying about with fitting, handbrake and speedo pickup, the weight saving (around 50kg) and the taller gearing of the suzuki box would be useful. Also the addapter plate and coupling are already there for the suzi box. The 11kw motor only spins to 2800revs and the standard gearbox has very short gearing. I'll keep you informed.
Ian
Electron
New EV project
Post by Electron »
Ian
Are you sure on the motor revs? I would have expected a series motor to rev to 5000rpm.
Have you seen any rpm/torque/current graphs?
What RPM did the Landrover motor rev to?
Ron
Goombi
Real Name: Eugen
New EV project
Post by Goombi »
Hi Ian,
I bought my first L/Rover short w/b in 1955 the most speed i got was 45 Mile/h which equals 72-75 Km/h as i recall the motor was whistling at that speed. whats more had it gone any faster i would possibly not been able to control the car.I hope the converting your l/r is the correct and practical way and you though it out fully Good luck Eugen
Shaggy
New EV project
Post by Shaggy »
Hi Ron,
I've just been to Solemn's site and entered the figures for a a series land rover suffix A for gearbox and transfer case. Have a look and let me know what you think. I'm not planning on racing anywhere but 80kph for a shot time might be nice.
Ian
Goombi
Real Name: Eugen
New EV project
Post by Goombi »
On e-bay electric Matise for sale in cubulture 1000$
http://cgi.ebay.com.au/Daewoo-Matiz-12- ... 2c53955e4a
Electron
New EV project
Post by Electron »
Ian
Had a look at the site. Yes you need a motor that does more than 2800rpm.
5000rpm would be best, closer to the original motor RPM
Ron
Shaggy
New EV project
Post by Shaggy »
Thanks Stephano, once we finalise the choice of motor we would like to take you up on that offer.
Ian
Shaggy
New EV project
Post by Shaggy »
Goombi
Thanks for all of your help so far but I think we are going to need to go with another motor for this project. If anything changes we will let you know.
Ian
Goombi
Real Name: Eugen
New EV project
Post by Goombi »
Hi Ian Thanks for letting me know, See you possibly at next meeting Cheers Eugen
Perhaps this web may help a little http://www.driveev.com/jeepev/home.phphttp://www.driveev.com/jeepev/home.php
dko
New EV project
Post by dko »
Hi Ron,
hope all is well!
Do you have something new about the EV Land project ?
Thanks Stefano
Adverse
Real Name: Ivan
New EV project
Post by Adverse »
Shaggy wrote: Goombi
Ian
you know there is a way to save about 400Kg or even more of steel (gearbox , 2 diff setups , 2 tail shafts , oils , CV's)
but it will take some engineering to do it
you could remove all the gearboxes and diffs
replace the rear diff with a light beam axle and the front with a lighter truck beam and king pin axle then run 4 X wheel motors, all controlled with separate controllers all reporting back to a central computer
that way the computer can tell a wheel that has lost traction to reduce driving force to say 5% till it gets traction again and stops spinning/slipping
this will save power loss not to mention act as traction control
not to mention when you are on the road you can just put power to only 2 wheels and let the other 2 freewheel
this may all be to much work for you guys to do but it would be a better way to do it
PS:- sorry to but in Image as i am a noob on these forums but have about 20+ years worth of mechanical experience on anything from go karts , formula V , custom car and truck modifications to building building a Lotus7 clone for a friend from the ground up this is not my site but its the same type of car
and i tend to think out side the box Image
suziauto
Real Name: graeme Manietta
New EV project
Post by suziauto »
expanding on adverse's idea.. maybe wheel motors derived from fisher and paykel smart drive washing machines inside the wheel rim? it would need to be rebuilt onto stronger framework maybe.. and then reverse them to make power when rolling or braking......they make good windmill generators
Shaggy
New EV project
Post by Shaggy »
The Motor arrived last week, it's a FB1-4001A. Now to the adaptor plate. I looked at the plate and coupling manufactured by Canadian Electric Vehicles but their picture shows a different bellhousing to the one I have so I am sending them a tracing to see if my bellhousing will fit. I'm not feeling too optomistic about it.
Stefano generously offered to manufacture an adaptor plate but needs a drawing in DWG or DXF format. Does anyone know where to even start with that? This would still require the manufacture of a motor coupling.
Looking at controllers, the origional suggestion was the Curtis 1321C but a what about the ZEVA MC600S? Any thoughts Ron?
dko
New EV project
Post by dko »
Hi Ron,
I am at disposal to manufacture the adapter plate !
As soon I receive the drawing, I'll produce it.
Ciao Stefano
dko
New EV project
Post by dko »
Hi people .... any progress about the new project LR electric ?
Ciao Stefano
dko
New EV project
Post by dko »
what do you think about this Land conversion :
http://www.axeon.com/News-and-Events/Ne ... ender.aspx
Goombi
Real Name: Eugen
New EV project
Post by Goombi »
Hi everyone DKO I thought you would have already finished your land Rover and went four wheel driving to Birdsville. In my opimiuon Don't do the conversion with land rover. LR has been converted from Nuffield tractor for war wehicle. One nice vehicle was built in gympie was PYZAR. perfect car --el. windows modern suspention Manual steering and its a 2001 model. lovely car to drive easy to assemble gearbox is smooth and the cost was average what one would expect for Home made conversion Even Brumby ute is a far superior car   for conversion to LR.
No hard feelings friend but you are on a wrong track In order to have a sucessful EV one has to choose the possible lightest car. SMART Mercedes will be good to convert with a blown motor? Very easy job semi auto gearbox 12 volt operated and assisted steering also with el pump. If I was doing my third conbversion that would be the car.. Smart choice Regards Eugen
Shaggy
New EV project
Post by Shaggy »
Hi Eugen thanks for your honest opinion. You are absolutely correct about the choice of vehicle but the idea behind this build is not actually to build the perfect electric vehicle but rather just to have some fun with what I think will turn out to be an interesting vehicle. Beauty is in the eye of the beholder as they say Image
The electric Land Rover conversion has started although it has not progressed as fast as I might have liked. I Gained a Board position as well as my day job and I found that between both jobs I didn't have much time left for the car and young family and house and garden...... The good news is I now have more time for the electric land rover so I should start to make more substantial progress soon.
I am planning on launching a blog soon outlining the progress of the build. It will be more of a car restoration blog that just so happens to be an electric vehicle build also. The fact that it is a total vehicle rebuild also explains why the project has been taking so long.
Thanks DKO for the offer but I already have the motor mounted to the gearbox with an adaptor and coupling I bought from Canadian electric vehicles. The plate was about 20mm too thin so I had to have a very large spacer made but that is a whole other story.
Hope to see you at the next meeting in Brisbane Eugen.
Ian
dko
New EV project
Post by dko »
Jan, thanks for the clear anwer.
I agree with you about the electric LR !
Anyway I remain at your disposal for everything
you need of mechanical parts.
Regards from Italy.
Stefano
Jeff Owen
Real Name: Jeff Owen
New EV project
Post by Jeff Owen »
Shaggy
The motor gearbox assembly would make a great show and tell item for the Brisbane branch meeting on Wednesday night.
Shaggy
New EV project
Post by Shaggy »
Hi Guys,
Can anyone suggest a good fabricator to weld some engine mounts and battery packs? I spoke with David of DB Autotech and the guy he used doesn't do it any more.
Thanks
Ian
I hope to make it to the meeting this month.
