Page 2 of 2
electric bike kit supplier suggestions
Posted: Fri, 04 May 2012, 03:25
by david s
Yes it has regen. You can also connect itsto your computer and adjust settings. It also has cruise control, which I really like. I do pedal, but not too hard, on the way to work, so no shower required. On the way home I usually pedal harder. This does not really affect the top speed, but simply takes some pressure off the motor and batteries,
Posted: Sat, 05 May 2012, 00:07
by PlanB
So you simply assist the motor by pedaling? No fancy pedal sensor or pedal assist circuitry required? Also how good is the regen going down hills? And are you able to engage it without applying friction brakes?
Posted: Mon, 24 Jun 2013, 02:25
by glenn_aircooled
With hub motors, when you just want to cycle along without using power assist , Does the motor slow you down .....
I mean is there spinning resistance to the wheel caused by the motor - which slows the bike.
I am thinking of the brushless DC motors. I imagine it would be a very small resistance if there is one.
Posted: Mon, 24 Jun 2013, 03:00
by david s
Yes there is resistance when pedalling without the motor, but in practice you never allow the battery to go flat so there is never a problem. With the Golden Motor the regen braking only comes on momentarily and you have to keep reapplying the brakes for more. At least thats how mine works.
Posted: Tue, 25 Jun 2013, 01:48
by unheardofinstruments
I have a recumbent and a motor on the chain so I can use the gears, 250 W in a low gear is great for hill climbing with the shopping and kid on board. Top speed test is for someone with bigger balls and a speedo, its a streamliner. Electric regen is only about 40% efficient anyhow just coast a bit faster.
Posted: Fri, 28 Jun 2013, 03:14
by glenn_aircooled
thanks for replies. So am thinking that I should go with the motor, independantly chain driving the back wheel. That way I can put a Cog with freewheel on it. The only extra friction when not using the motor would be the friction inside the freewheeling cog.
Posted: Sat, 31 Aug 2013, 04:05
by cobber
Hi, If you want to build a legal bike and get usable performance you best choice is to buy a mid motor kit. Better hill climbing, higher top speed and longer range from the battery. The best known and longest running manufacturer is Cyclone Taiwan. The better choice for value for money without compromising quality is GNG. They make kits for legal power bikes. There off road high power kits are capable of higher speeds. 3 weeks ago they released a 60 volt kit capable of 90 Km/Hr without mods.
All you have to do is look on Ebay, they are all listed there. Don't listen to people talking about what they did last year, or was it the year before.
Posted: Sun, 01 Sep 2013, 00:59
by david s
Thanks Cobber, have you got a link to GNG?
Posted: Sun, 01 Sep 2013, 04:58
by cobber
GNG have a website with online store.
http://www.gngebike.com
They also sell on Ebay.
http://www.ebay.com.au/itm/60V650W-CHAI ... 2c71f1a5e3
An Australian manufacturer with high quality.
http://www.af-tech.com.au/Products_Ebikes.html
Another cheap chinese company.
Good engineering and headlight included. Lowest price.
http://www.hi-well-f.com/index.htm
