in an effort to get my head around the power required to make things go I thought I would ask what likely to be a prety dumb question but I can't really find the answer anywhere. We have a couple of motors in the shed, the details are as follows:
Type kevmxx induction motor
volts 415
poles 4
cont rpm 1440
rotor c
hz 50
hp 2.5
code k
insulation j
These are pretty heavy for 2.5hp.( 20kg?) They look very much like your standard industrial motor. The pool pump 240ac motors we have are much smaller for the same power! My question is this...I read about you guys pulling as much as 3 times the rated output? are these the sort of motor you can do this with? How big would the controller be? I saw in one post the AC controller weighed 59kg!(Albeit for a small car) Is there an AC controller that will produce 3ph AC from 72v DC? (pie in the sky plan is 72v)
Are these motors suitable for a motorcycle? they are around the size I would expect to have to fit to a bike but they are no where near the power I would expect to need. Is industrial AC more suitable for a car given the extra weight due to industrial strength?
Any help would be appreciated
Thanks
Ken
