Schaeffler E-Drive
Kasterborus
Real Name: Chris
Schaeffler E-Drive
Post by Kasterborus »
So I have been looking at drop in Electric Drive setups, as I plan to build my own skateboard, but I can't seem to track down any more information on this one:
Schaeffler Symposium 2017
Schaeffler Symposium 2018
Schaeffler Symposium 2018 PDF
YouTube Video about it
francisco.shi
Real Name: Francisco
Re: Schaeffler E-Drive
Post by francisco.shi »
What car are you planning to convert?
Kasterborus
Real Name: Chris
francisco.shi wrote:
Mon, 27 May 2019, 07:19
I was considering a small 4WD or an old ACCO truck
francisco.shi
If you are interested in something a little simpler would you consider the motors and cells I am using?
Kasterborus
Real Name: Chris
Thu, 06 Jun 2019, 07:46
Simple is always better, what's your stuff?
francisco.shi
I have a motor with a 2.56:1 planetary gear box with built in inverter. It was designed to drive a right angle diff directly.
The output of the motor is 260Nm peak and top speed 12000rpm.
The output of the gearbox is 3000rpm @660 Nm peak.
It will be too fast to drive the wheels directly but if you do not mind having a motor for the front and a motor for the back it will work ok.
You can see the motors and how they mount in the Francisco's electric pajero build under members machines.
Kasterborus
Real Name: Chris
Fri, 07 Jun 2019, 12:52
Sounds good man, I'd certainly be interested in them, can you PM me some more info?
