Need help.
Posted: Thu, 21 Feb 2013, 14:55
by Canberra32
Hello to there everyone.
I need some help deciding on the drive system of the bike I'm building.
I'm at the stage of purchase the motors and am stuck between hub and regular.
I have found some 10&8kw continuous brushless hub motors but am also looking at twin mars ME0913 motors.
While hub means more room in bike and ultra simple build it also means more weight unsprung.
The mars motors do kill space in the bike but have a higher power.
The bike is a cruiser not unlike a low riding chopper
310 wide wheel at the back and 160 front so it's a biggin.
Weight anywhere in the 300kg is normal for a bike like this.
I see my tail and I can not stop chasing it!!!!
Please people slap me hard and point me in a direction!!!
Need help.
Posted: Thu, 21 Feb 2013, 15:41
A 300 kg bike and a pair of Mars motors is not a good combination. It will move it, but you might be disappointed. Managing a pair of motors is more than twice the trouble of managing one big motor.
Trouble is, there's nothing in the 20-40 kW single motor region ideally suited to bikes. You could try an AC20 induction motor?
Need help.
Posted: Thu, 21 Feb 2013, 20:51
Usually the hub motors are a generic fit.
So don't quite fit, don't quite look right and as you say have limited power.
I agree twin motors is asking for trouble - unless your sticking a chain to each side of the wheel Image
::bites tounge:: The 6.75" DC motors do suit it
Regen from AC is not much use on a rear wheel bike anyway.
Need help.
Posted: Thu, 21 Feb 2013, 23:15
by Canberra32
Not so sure.
The rear brake dose come into play in a cruiser quite a lot.
Need help.
Posted: Fri, 22 Feb 2013, 00:24
Supposedly the AC-20 "is a very popular choice for motorbikes".
C-face 96V
http://www.bylongind.com.au/curtis_opti ... parts.html
http://hpevs.com/Site/power_graphs/metr ... metric.pdf
Still you'd have to wonder if an extra $2.5k for AC is worth the marginal benefit over the DC 6.75" system.
Need help.
Posted: Fri, 22 Feb 2013, 03:38
by Canberra32
I did check that out...
Even the AC50 dose not have the same power as 2 ME0913s and the two are lighter.
And while 6.75" is nice for postie... If I go DC no less than 9" if I go DC I go it hard :)
Sofar still tilting towards the two mars motors :)
Need help.
Posted: Fri, 22 Feb 2013, 04:02
That's the power of permanent magnets for you. PMAC has it over induction when it comes to hard throttle use. But for cruising they are on par.
It's just that managing a pair of motors is trouble with a capital F. Two controllers? Lots of space used up for something that could have been a single motor of more power? It's a tough call I know.
You can always try an AFM130 Image
Need help.
Posted: Fri, 22 Feb 2013, 04:26
by Canberra32
Room is not to big an issue as with a sports bike.
Weight might be.
Found a dual hub motor single wheel for bikes :) 20kw cont :)
Need help.
Posted: Fri, 22 Feb 2013, 20:54
So what your saying is you want about 60kW?
Even tho a car twice as heavy only has 40kW.
Are you sure you want this for "Cruising"?
Dual ME0913 are 32kg which is about 3kW 100-frame for industrial stuff.
Which would mean spinning upto 7500RPM for a peak and 9000RPM max.
Sounds a bit unlikley for that at this stage.
How about using the two ME0913 each with a seperate "primary" chain/belt to a common shaft which then has the main chain run to the wheel.
At this stage it would be cheaper than the AC50.
Assuming you can get a controller (or two) for the ME0913.
I see evworks has controllers for it listed as "coming soon".
Need help.
Posted: Fri, 22 Feb 2013, 21:01
EnerTrac DU-602
http://www.youtube.com/watch?v=zwIdXw3A ... MQ&index=2
Made for the Akira bike movie - need I say more Image
Need help.
Posted: Fri, 22 Feb 2013, 21:37
by Canberra32
Yup that's the motor I'm looking at :)
Need help.
Posted: Fri, 22 Feb 2013, 21:38
by Canberra32
And Kelly controllers dose a duel ME0913 kit :)
Need help.
Posted: Sat, 23 Feb 2013, 22:17
by Canberra32
Dose anyone currently have a mars ME0913 in a motorbike on here?
Need help.
Posted: Sun, 24 Feb 2013, 02:00
Dan Sailer did, but he hacked and modded it, and then added another one. Hit up EV album and try to find one.
Need help.
Posted: Sun, 24 Feb 2013, 03:12
by Canberra32
Ok after much research I find that the two ME0915s will do just fine.
Example
My Suzuki 1500 intruder had 67hp 115nm and weighed 315kgs
Twist throttle and try not to slide back over seat....
The two mars motors have the same sort of power but geared 2.2:1 give an increase in torque over the Suzuki so I think I'm on the right track :)
