So, to tabulate:
Stiive's contact
Siemens motors @ $1666ea (MOQ: 6, motors only)
Lloyd/Andy
AC Pumps- 17 available, price £175 each. (AU$270)
GearBox- 2 available, price £1500 each. (AU$2305)
Motors- 16 available, price £1800 each. (AU$2766)
Heaters- 5 available, price £175 each. (AU$270)
Inverters-15 available, price £1000 each (AU$1540)
Water pumps-64available, price £75 each. (AU$115)
Vacuum pump- 2 available, price £75 each. (AU$115)
Package of all the above. (AU$5840)
Adam
DMOC645 liquid cooled. 160kw. US$1250
Siemens 5135 212v rated bus. US$2000
AC24LS US$200
If you just want a motor, Stiive's contact is going to be the way to go
If you want a motor and controller package, Adam is the way to go
If you want a complete package, Lloyd is the way to go
On a related note, I've downloaded all the AZD software tools for programming the transit connect van.
Zipped and available here (130MB). I haven't had a play around with them yet, but I'm hoping they're all that's required to program those controllers. Someone will need to either get a hold of a programming tool, or design one.
One possible stumbling block I've found in the manual is that the PPR count for the encoder may not be able to be set from software and may be tied to the Siemens motor ("EE1EncoderPulses Pulses per motor encoder rev; Azure internal use only"). The same is true for many other motor parameters. This is fine if you get a package, but if you want to run any other motor from one of those controllers, it might be tricky.
