I finally decided to overclock my small 1.5kW 4-pole IM before I move onto something larger.
The current stator windings are as follows
Now you may notice that there are 4 pole windings (no consequential poles), however 2 of the poles have a double winding... (as seen in the diagram above by parallel lines at the bottom).
Here is a pic of the double pole (left) and then single pole (right) for phase U. The double pole has the same amount of turns in each winding.
Now I'm a bit at odds whether to put the double windings in parallel, or leave them in series. I'm doing parallel atm. I've already snipped all the phase W connections. I'm running all wires back to the terminal box and its already crowded just after phase W (12 wires per phase!).
Seems a bit weird one pole pair in each phase is half the strength of the other? Guess it evens out as each double pole is overlapping with another phase's.
Pretty excited to get this running, was getting about 2kW out of it @ 100V, but the stator resistance was too high to get any more with my voltage restriction.
Question is, now that I'm paralleling all 6 windings per phase, is this a 1/6th voltage clock?
