Golden Motor - any experience?
LightningEV
Real Name: Robert James
Post by LightningEV »
I just checked back with kelly and they have updated their product list since I last spoke with them.
I can only assume that they were incorrectly quoting their controller specifications as they have now changed the specification considerably.
Sinewave controllers are not that difficult tho they do incur a higher production cost, but there are plenty of VV VF drives on the market if you know where to look.
I understand the mechanics of using harmonics to modify the square wave to create a "modified sine wave" of sorts, but outside of model aircrafts and pushbikes the cost saving is negligable.
The HPM-10K is suppose to utilise an encoder for phase timing. Atleast this is what I was Informed some time ago.
Back emf controllers considerably lack the starting torque required in an Electric car and the ones I have seen do not have a great efficiency which frankly is the only reason anyone would look at a PM setup.
In theory the losses might seem the same, but when you look at whats available on the market you generally wind up with BLDC motor/controller operating at 85%EFF and PMAC motor/controller operating at 90%eff, It may be that PMAC systems are available in larger setups and this could account for the differences in Efficiency.
Progress was never made by thinking Inside the box.
