Page 1 of 1
AC motor big words
Posted: Thu, 12 Mar 2009, 20:03
by HeadsUp
i looked at some 3 ph motors , which are labelled in their spec sheet as ;
Motor (VAC) - 22/15x3 kW
22 kW peak , 15 kW continuous ?
what does the " x 3 " mean ?
it is from a lathe spec sheet , and mentions a 22 minute duty cycle , but no percentage , maybe its 22 minute continuous at 22 kW ?
max 5,000 min-1
22/15x3 kW
350 N•m (257 ft-lbf)
AC motor big words
Posted: Thu, 12 Mar 2009, 21:16
by Richo
maybe give us a link.
Unlikely a lathe is going to be using 15kW continuous.
Maybe more like the 3kW at 22min on 15min off?
AC motor big words
Posted: Thu, 12 Mar 2009, 23:07
by HeadsUp
http://www.okumaaustralia.com.au/produc ... B4000%20EX
there is a list from small to large lathes , 7 kW to 50 kW , click on the lathe model , then click the PDF , it will show spindle motor kW
this is the current model series , many of which have a hollow shaft direct drive motor , the older ones had standalone motors with belt drive.
edited: many CNC lathes will run all day , using auto bar feeders , program the machine from the office , walk down and check a sample and employ a 17 year old kid to drive a forklift replacing the finished product feed bin every 3 hours.
i dont expect a current model motor to be cheap , but second or third generations back there could be good technology and cheap second hand stock.
thankyou.
AC motor big words
Posted: Fri, 13 Mar 2009, 07:32
by Richo
Mmm Interesting.
A gearbox helps reduce the peak power requirements.
For example using about 85kW peak motor will get a BMW to 100 under 8 secs using a gear box.
Using the motor direct drive it would be about 15 seconds (Slower than the original car).
To achive the same results without the gearbox I need more like 140kW peak motor power.
The 30kW lathe motor has a sync RPM of about 445RPM and 700Nm.
The 30kW is fine for continuous but you will need more for acceleration.
Lets say you reconfigured the motor (rewind) and got it to produce 90kW.
Thats 700Nm out to 1335RPM.
On the BMW this would peak out at 35kph.
After that the acceleration would drop off.
And would take about 19sec to get to 100kph.
Which is reasonably slow - nearly twice as slow as the original ICE.
Assuming that these lathes run from 415V 3-phase.
You would still need to modify the motor to get the peak power.
ie rewind for about 120V ac.
Being a spindle motor for a lathe with a hollow centre you would also have to provide a custom shaft to couple to the diff. (140mm dia)
It would be similar to doing an eV conversion with a 16-pole Induction motor without being supplied a shaft.
Sounds like a lot of work.
btw I couldn't find the reference to the x3.
So I don't know what it is for.
But it would be 22kW for 30min or 15kW continuous.
AC motor big words
Posted: Fri, 13 Mar 2009, 07:42
by HeadsUp
beautiful . thankyou kindly
agree that the hollow shafts would add extra weight and machining , but the older generation were plain keyed shaft
funny if i email the Okuma tech department , they might say " sorry ... sir the x3 is a typo "
thanks Richo.
AC motor big words
Posted: Fri, 13 Mar 2009, 07:55
by Richo
Yep typo.
It's good to see you are thinking outside the box for suitable parts.
Don't get me wrong - It would work
it's just a question of cost and extra effort to get it to work.
If the weight of the motor is under 120kg you could have a motor with massive potential ie 200kW+.
But still a lot of changes to work properly.
And no guarantees of working or performance.
AC motor big words
Posted: Fri, 13 Mar 2009, 08:44
by weber
Richo wrote:A gearbox helps reduce the peak power requirements.
You would need a motor capable of 140 kW peak, but would you actually need to _use_ that peak? Couldn't you still have a VF drive and battery that were only capable of the 85 kW, thereby shaving that peak, and still do quite well?
AC motor big words
Posted: Fri, 13 Mar 2009, 09:13
by antiscab
for direct drive you build your controller and motor to be so powerful that you have the same power available at low speed as you do at high speed.
This means the setup is capable of *far* more power than the batteries can put out.
you cant get away with a smaller vfd, as you need the higher motor side amps, to drive the bigger motor, to get the higher torque needed to get the same power at lower rpm.
instead of only needing that 85kw as a peak value, with direct drive, you need it as an *average* value.
the funny thing is, a gearbox limits you to a lower power motor, so it removes any upgrade potential.
AC motor big words
Posted: Fri, 13 Mar 2009, 09:23
by Richo
Assuming it was the bigger motor - sure.
Having a bigger motor is more efficient too
Plus no gearbox for lower losses and things to break
Prob may not even need to rewind it either.
Just buy and put in.
A lot more simple than trying to get a lathe motor to work
Know of any cheap ali 180-frame motors?
AC motor big words
Posted: Fri, 13 Mar 2009, 09:27
by weber
antiscab wrote:you cant get away with a smaller vfd, as you need the higher motor side amps, to drive the bigger motor, to get the higher torque needed to get the same power at lower rpm.
But at lower rpm, you have some volts to spare, so you trade them for reduced amps by switching your motor from delta to star. Then you require only 0.58 of the current but must put in 1.73 times the voltage. Does that get you down to an 85 kW VF drive with your 140 kW motor and still give max torque at low revs?
AC motor big words
Posted: Fri, 13 Mar 2009, 09:33
by Richo
antiscab wrote:the funny thing is, a gearbox limits you to a lower power motor, so it removes any upgrade potential.
Not if you buy 1 small one to go on the box.
Then later buy another exactly the same.
Ditch the box couple the two together lengthways.
Now you have decent direct drive.
The numbers work.
But really who wants a box?
when you can play with
these...
AC motor big words
Posted: Sat, 14 Mar 2009, 06:49
by acmotor
Don't show Andrew !
AC motor big words
Posted: Sun, 26 Apr 2009, 06:17
by Nutz
Can somone translate the info in this for me and let me know if it is big enough for an EV? It has agreat retro look for my old Mazda.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 2759.l1259
AC motor big words
Posted: Sun, 26 Apr 2009, 06:35
by woody
Sure. 1/3HP = 0.25kW. Would only be enough power to run the demister fan unfortunately.
You'll be looking for a 15-20 HP (11-15kW) 4 pole (~1450rpm) 3 phase motor, which will weight 60-100kg.
Controller you'll want 22kW (cruisy) or more (55 - 75kW is high performance) 3 phase which will be 10-75kg.
Voltage will probably be ~400V AC in australia which will need 600V DC batteries.
3 phase 240V AC is US/Japan spec, but more weight per kW.
For retro, you can fake it if you want
cheers,
Woody
AC motor big words
Posted: Sun, 26 Apr 2009, 06:45
by acmotor
Sorry Nutz, that motor is not even retro. Scrap copper value only.
The seller is smooth with his words, maybe he'll find a buyer !
It is amazingly heavy at 20kg for 1/3 hp. (250W , 0.25kW)
You need a motor with 100x times that power for an EV.
Single phase motors are really not an option for EVs. Their power to weight is very low and efficiency poor. The main problem is their lack of starting torque compared with 3 phase motors.
edit: nice overlap there woody !
AC motor big words
Posted: Sun, 26 Apr 2009, 18:01
by Nutz
--Gulp, that's 50 x 12 volt lead acid or 200 x 3v Thundrerskys...at least you would not have to use the 90amp hour ones.
--Would this be greater than the weight offset by halving the battries?
AC motor big words
Posted: Sun, 26 Apr 2009, 18:31
by HeadsUp
The Brusa controllers are 120 - 480 VDC
whether you have 200 x 40 AH batteries , or 100 x 80 AH , you still only get driving range from the kW/hrs of battery you have on board , and battery cost is the same per amp hour if using TS batteries.
you would however save money with having lower battery pack total voltage by requiring fewer BMS units ,fewer cabling connections , and battery charger requirements may also be a bit lighter
http://www.brusa.biz/products/e_dmc514378.htm
looks like very nice quality device on paper , but currently too expensive for the likes of us ,obviously its more logical for them to focus on selling packages of 50,000 units per order to Volkswagen , BMW mini , Renault etc
Azure also looks like a nice package , but again , the pricing is not there.
from Blade Electric Vehicles
AC24LS motor for US$2895
DMOC445 controller for US$3495
AT1200 gearbox for US$1695.
For larger applications;
AC55 for US $3495
AC90 for US$4695.
some people here have built perfectly good EV's using Danfoss controllers ( approximately $ AUD 2500 controller , and a 415 v 3 ph motor $ 1100 - 1500 )
for a decent range , my calculations come up with around 28 kW/hr of battery which will bite a hole in your bum where your wallet used to be to the tune of around $14,000
hope that helps
