Anyone looking for a 100-200VDC 3.3kW charger for their EV conversion? I have a Dilong DA3K3M17-150C that I'm looking to sell. It was purchased direct from Dilong last year for evaluation (prior to ZEVA finishing up), but other than briefly testing on the bench to make sure it works, it is brand new / unused. It is CAN bus controlled and uses the same protocol as TC chargers, so you'd need a BMS or similar device that can send it the control message - I can arrange a controller board if needed. Asking $495 (below wholesale cost).
User manual: https://www.zeva.com.au/DA3K3M17-150C.pdf
[SOLD] Dilong DA3K3M17-150C charger (100-200VDC, 3.3kW), $495
- Real Name: Ian Hooper
Ian Hooper
http://www.zeva.com.au
