39kw solar array on gumtree
https://www.gumtree.com.au/s-ad/redclif ... 1244900823
Does say whether it includes railing, though likely not
most likely panels are no longer fire rated for on building use and they're upgrading with all new
$3500 for 39kw of panels is still pretty good - $23 per 250W panel
$5000 for 39kw and 30kw worth of inverter
anyone interested in going in shares?
Re: 39kw solar array on gumtree
I'm sure there's the odd farmer who'd be interested. Tuarn has a bit of a solar panel buying problem, this might not help him though hey @acmotor ?
