Ev parts
Dan007a
Real Name: Daniel Andrews
Ev parts
Post by Dan007a »
Re: Ev parts
That's a bummer. What voltage is the DC/DC converter designed for?
Re: Ev parts
For some reason I only get the photos now on Gumtree, none of the text description. I'm running IE 11 so maybe there site people no longer support IE.
Re: Ev parts
Copy paste of the ad
Full ev mechanical conversion.
Fb1-4001 motor 200km of use
Curtis controller 15k use
Thunderstruck tsm2500 charger needs evcc
Mounting box
Vacuum pump
12v power steering
Around to 90kgs .
Re: Ev parts
Thank you Brendon, much appreciated.
The Fb1-4001 has a max voltage of 144vdc, is that nominal as in 45 cells @ 3.2v nom. or a ceiling upper voltage limit? Could it be used with another controller at say 273.6vdc max, nom. 243v, 76 cells @ 3.2v nom? Maximum RPM would be insane and useless really, but the torque figures would be a lot better and the curve a lot flatter wouldn't they .... or would the smoke just come out?
Re: Ev parts
above 45 cells you get arcing at the brushes (ends up being around 130v)
Some motor controllers allow you to set a motor voltage limit, allowing you to use a higher voltage pack
max rpm is still a mechanical limit, starting at around 5500rpm when cold and falling when hot (the banding weakens with temperature)
Re: Ev parts
Thank you Matt. Should have realised it would be a brush type motor and I have no interest in those. Price was certainly good for anyone who was after that sort of thing.
