Working DC Powertrain parts for sale
gmacd33
Real Name: Greg MacDonald
Post by gmacd33 » Sun, 07 Feb 2016, 22:16
The time has come to sell my first EV conversion - the Kia Rio. It's still working, and capable of 110kph on the highway easily, as well as going over the Gateway Bridge. However the batteries are tired and probably need replacing - at least some of them. It has a manual gearbox with clutch removed.
So I'm selling the parts individually, or as a project for someone to take on and simply replace the battery pack.
Parts are as follows - if you're interested, make me an offer!
  • Netgain Warp 9 DC Motor - $1,500 ono
    Zilla Z1K 1000A motor controller - $1,800 ono
    Power Steering Pump kit (with hydraulic fluid, hoses, connectors, etc)
    Brake Vacuum Pump kit (with reservoir, check-valve, sensor, relay etc)
    2 of Gigavac HV Contactors
    2 of 300A HV Fuses
    55A DC/DC converter
    2kW Masterflux Air Con System (brand new!)
    Metal Structure to fit 100Ah cells - 20 and 25 together
    Inertia Sensor
    Pot sensor kit for accelerator
    Other miscellaneous items for above - cables, connectors, relays, fuses etc.
Greg MacDonald
Chief Technical Officer
Lithium Battery Systems
043-848-0011
greg@lithiumbatterysystems.com.au
Post by 4Springs » Mon, 08 Feb 2016, 00:20
It is annoying that this section is for members only. Means that you have a narrower audience for your ad than if you put it in another section.
I've taken a screenshot for someone on facebook who is looking into a conversion. Image
evric
Real Name: Eric
Post by evric » Mon, 08 Feb 2016, 05:38
Hi Christopher,
I think non-AEVA members can view this area, they just can't post anything.
They should be able to PM.
Eric
Post by 4Springs » Mon, 08 Feb 2016, 12:35
evric wrote: Hi Christopher,
Eric
Yes, but you have to be a member of the forum. Anyone else gets an "Access Denied" error. So I can't post a link to Facebook, and people using google search will not find this page (even if they themselves are a member, google is not).
Other parts of the forum are not restricted like this.
Post by Adverse Effects » Mon, 08 Feb 2016, 14:36
i think the reason that was done is because people may put contact info in that section and you wouldn't want that out on the net
Post by T1 Terry » Mon, 08 Feb 2016, 19:16
Give us a hint of what figure you are looking for as a complete rolling unit. Is it still registered?
gmacd33
Post by gmacd33 » Sat, 19 Mar 2016, 19:55
Righto folks, I've sold the batteries, BMS, charger, cooling system!
I've added pricing to the motor and controller; for the rest assume about half the price of new. Or make me an offer!
Please text or email me as below, as I don't check the forum messenger often enough :-O
Greg MacDonald
043-848-0011
gmacd33
Post by gmacd33 » Sun, 17 Apr 2016, 16:27
All parts are now sold! Now all I have left is the base car - would make a perfect starting vehicle for someone else who is keen to do a conversion - I'll post separately...
Greg MacDonald
043-848-0011
