Electrolux for sale
Electrolux for sale
Hi Guys,
I never did find the time to do anything with the Hilux, originally converted by a4x4kiwi
It's now taking space in my shed that I need for prius pojects.
To recap, it has:
1 x ABB 15kw 4-pole induction motor mounted directly to the diff
1 x danfoss VLT 5042 50kVA vfd
I will be including a EMW PFC charger kit - my plan was to modify it you use the boost PFC stage only to charge up to 900V using the VFD's internal caps and heatsinks
I will also be including the 600 x 1.2v 30AH Nimh batteries I was planning on using with in the conversion
The conversion does come with the engineering certificate original obtained by Mal - this covers the motor, and battery mounting (as long as you keep it in the tray)
There will be a fair amount of work involved in getting the battery in, but the bits are all there
not sure what it is all worth, but if you are looking for a project, this one might be for you
Electrolux for sale
original for sale thread from when I bought it:
viewtopic.php?title=for-sale-electrolux ... 62&start=1
Electrolux for sale
Give me an idea of what $$ you are looking for and how much to get it back over this side of the country. I'm still kicking myself for not grabbing it when 4 x 4 Kiwi put it up for sale, I just didn't have the confidence or any understanding of EV at that stage. Still not sure I have the knowledge but I'm feeling a little more confident :lol:
Electrolux for sale
T1 Terry wrote: Give me an idea of what $$ you are looking for and how much to get it back over this side of the country. I'm still kicking myself for not grabbing it when 4 x 4 Kiwi put it up for sale
I'm kicking myself to buying it to be honest, I have soo many projects on the go
I was hoping for $4k for the lot (batteries, charger kit and ute)
shipping it over here cost me $1500, but I think it's cheaper if sending back over east
Electrolux for sale
Is this similar to the Tesla battery pack? They use Ethylene Glycol I believe to temp control their battery pack and I believe Nimh cells are temp sensitive when it comes to charging and discharging. I believe there is an issue with another vehicle manufacturer using a similar battery technology but not using temperature control with their battery pack and they are experiencing capacity reduction, so would I need to design a battery pack heating/cooling system if I went ahead and used these cells?
Electrolux for sale
Hi Terry,
These cells originally came from Vectrix scooters, which were indeed suffering capacity loss due to poor battery management (including temperature management)
part of the problem was the cells were being charged quickly (which heated them), being overcharged, and then left warm at full charge for long periods
my long term plan was to make battery boxes for under the tray (keeping the battery out of direct sun light, but needing a new engineering cert).
I wasn't going to go beyond fan cooling
for a nominal 720v pack, charge rate was never likely to be a problem (6A or less is ideal, but that's near 5kw and less is better)
overcharge is easier to avoid if not charging quickly
If it didn't work I was going to go lithium later on
Electrolux for sale
bump
looking for any offers on this - the ute just takes up space in my workshop now
It'd be great with ~90 x leaf modules :D
Coulomb Racing
Real Name: James Hill
Electrolux for sale
Post by Coulomb Racing »
Hi Antiscab,
Would you consider selling the batteries on their own?
Regards,
James
Please like us on Facebook: Coulomb Motorsport
Electrolux for sale
antiscab wrote: bump
I've sent you a PM, still kicking myself for not buying it when 4X4Kiwi had it up for sale
Electrolux for sale
Sure, I'm happy to do that
The batteries aren't actually in the ute, so very easy
I'll PM you with more details
Re: Electrolux for sale
