Industrial style motor couplers
BigMouse
Real Name: Vincent Tannahill
Post by BigMouse » Fri, 04 Jul 2014, 21:06
I bought these couplers intending to build a dyno for testing my controller. They are rated to something crazy like 900Nm. I've got the taperlock bushes for them to suit 38mm motor shafts (132 frame standard), and the rubber piece that goes between the jaws of the couplers.
This could be good between two motors in a siamese arrangement, for a dyno, or to couple a motor to a very large transmission input shaft (truck?, bus?). For an idea of size, the centre bores on the taperlocks is 38mm, the OD of the couplers is 175mm. They're pretty chunky.
$100 for the set, or make an offer.
I'm in Wollongong, but can ship if you need me to.
BigMouse
Post by BigMouse » Tue, 05 Aug 2014, 00:21
Sold
Post by Adverse Effects » Tue, 05 Aug 2014, 04:05
oww EV porn
Post by Richo » Wed, 06 Aug 2014, 00:09
Any leads where others would buy such beastie bits?
Post by Adverse Effects » Wed, 06 Aug 2014, 00:27
SKF bearings sell that type of stuff
Last edited by Adverse Effects on Tue, 05 Aug 2014, 14:30, edited 1 time in total.
