For sale: Electric pushbike (ebike)
Post by BigMouse »
Just looking for the value of the hub motor and battery kit. The bike needs work (tyres, rear sprocket freewheel, front forks are all worn). For best results, I'd swap the electric kit to a bike in better condition. The battery is a year old, 10ah lithium. The front hub motor works great and really helps when riding up hills. I commuted to uni on this bike for 3 years. Can cruise without pedalling on level ground. Front wheel is missing a spoke, but still runs true.
This is a 24v 200w system being run on a 36v battery. It has more than 200w ;-) No problems with heat, though good airflow is recommended.
$300 ono in Wollongong
I also have a 400w rear hub motor kit without battery you can have with this. The wheel needs to be trued up as it's a bit eccentric when riding. Can only really tell when applying the brakes on it.
Post by BigMouse »
Gone
