A few Tri-win DC40D-1250 water pumps, $30ea
zeva
Real Name: Ian Hooper
Post by zeva »
Hi all,
I recently looked into getting a small pump for the water cooling circuit in my RX7, and after a bit of a hunt found a model with the right specs from a company called Tri-win. Unfortunately their minimum order was 5pcs, so I have 4pcs spare! So, does anyone need a cheap water pump (for motor controller cooling circuits, etc)?
- Model: DC40D-1250
- Magnetically coupled brushless DC motor
- 12VDC 1.1A power consumption
- 450L/hr flowrate (i.e 7.5L/min, as recommended by Zilla manual, also good for Solitons)
- 5M water head pressure
- IP68 sealed but not intended to be submersible, i.e don't use one in your fish tank
- 10mm inlet and outlet (same size as Zilla and Solitons so you won't need hose adapters)
Asking $30ea (what they cost me), plus postage - probably $8 Express Post bag is going to be easiest.
Ian Hooper
http://www.zeva.com.au
I might buy one off you Ian - My Evo motor calls for 8 l/min so I reckon it will work just fine.
Bring it to the next AEVA meeting! (There's my bribe for attendance Image)
Ian, what temperature is the pump rated for?
zeva
Post by zeva »
Hi TJ,
Rated for 60degC - a little marginal for a cooling circuit I'll admit, certainly couldn't use it to water cool an ICE, but it is probably good to keep EV gear running below this temp anyway!?
Ian Hooper
ohmboy
Real Name: Mark Taylor
Post by ohmboy »
Are there any water pumps left?
Mark
www.evalbum.com/1608
Headway, Soliton, Advanced DC, Batrium BMS
