for sale: Electric Datsun 1200 ute
Brett_celicacoupe
Real Name: Brett
Post by Brett_celicacoupe »
Item: 1979 Datsun 1200 ute converted to electric drive
Item Condition: good condition
Reason for selling: I like building these projects more than using them, getting rid of this one makes way for the next, whatever that is
Price: 11,000
Extra Info:
-1979 Datsun 1200 ute
-body has been fixed up including bare metal respray, rust removed. the body is not perfect but it is clean
-kostov K9 144v motor
-soliton 1 jr motor controller
-13 x optima yellowtop 75ah batteries (four in front, 9 in rear)
-2kW TC charger from china
-200w worth of solar panels on tray (hardcover tanneau cover style)
-320w meanwell power supply
-traction pack e-stop (between seats)
-complied and registered in qld
-range is about 30-40km
-charge time approx 5 hours
-datsun 120y front struts and disc brakes
-VDO tacho and rev limit enabled via soliton
-vdo fuel gauge driven by soliton
-toyota supra leather seats
-13" mags
-CD player
-has clutch and standard four forward gears, 1 reverse
Other comments:
-pulls just over 500A on take off so that is about 70kw of electrical power which is more than the factory datsun power output of 50kw
-lead acids were used to allow larger power output for the capital outlay
-batteries could be replaced with lithium, or an additional set of batteries could be installed for more range
-no RWC but could be obtained if necessary
-car drives like it did before the conversion
Pictures:
copy/paste link into browser
http://imageshack.us/photo/my-images/850/dsc01958m.jpg/
http://imageshack.us/photo/my-images/534/dsc01959e.jpg/
http://imageshack.us/photo/my-images/9/dsc01960ca.jpg/
http://imageshack.us/photo/my-images/13 ... 961kl.jpg/
http://imageshack.us/photo/my-images/69 ... 962ya.jpg/
http://imageshack.us/photo/my-images/94/dsc01963vh.jpg/
http://imageshack.us/photo/my-images/26 ... 957jq.jpg/
Last edited by Brett_celicacoupe on Thu, 14 Feb 2013, 16:47, edited 1 time in total.
Brett_celicacoupe wrote:copy/paste link into browser
Or, you could put [ img ] and [ /img ] (removing the spaces) around the URLs, and we could see them without copying each link individially:
[ The images above are copied below with img tags as mentioned above: ]
Except it doesn't seem to work. Surely it's not because the images are too big; they aren't served from AEVA. Oh well, I tried.
Brett_celicacoupe
Real Name: Brett
Here is one of the images Image
Brett_celicacoupe
Real Name: Brett
how would one go about editing a post. It appears that this cant be done? or am i missing the button?
cheers
brett
evric
Real Name: Eric
Post by evric »
Hi Brett, Edit is under Post Options on the top right of each Post.
Eric
Brett_celicacoupe
Real Name: Brett
thanks evric, there must be a privilege issue. all i get under post options is quote and post reply (2 options only)?
cheers
Brett_celicacoupe wrote: all i get under post options is quote and post reply (2 options only)?
Even for other people's posts, I see three options (third is Report Post). Maybe it's because you are a Noobie (just haven't made enough posts yet)?
Perhaps a kind admin will upgrade your status, since you are obviously not a spammer.
Brett_celicacoupe
Real Name: Brett
I just checked and i do have the edit option in my other thread but dont here.
any ideas? i would like to change original post and edit price etc
cheers
Brett
Andrew
Real Name: Andrew Brown
Post by Andrew »
Brett_celicacoupe wrote: I just checked and i do have the edit option in my other thread but dont here.
cheers
Brett
Hi Brett, you now have permission to edit your posts in the for sale section. The issue was that you have under 30 posts and not listed as an AEVA member.
Brett_celicacoupe
Real Name: Brett
hi andrew,
thanks for your help, the issue appears to be resolved.
Regards
Brett
Brett_celicacoupe
Real Name: Brett
price drop $11k
