SAFETY SWITCH & pressure switch 20 HG
Goombi
Real Name: Eugen
Post by Goombi »
Emergency switch single pole 250 Amp $42.00 plus postage
Pictures on ebay# 330326514791
Admin edit: image fixImage
Vacuum Pump cut off switch
Up to 20 volt-- 20 HG 15 amps
No need for relay--- ok up to 15 amp. 15 amp Fuse in line OK.
$ 39.50 Post free Au This switch is adjustable for lower HG's or to suit your pump
evric
Real Name: Eric
Post by evric »
Goombi,
What are the switch contact current ratings?
Ric...
Goombi
Real Name: Eugen
Post by Goombi »
When you say "Double Pole also available for AC- EV's", can you tell me the voltage rating on these switches please.
Goombi
Real Name: Eugen
Post by Goombi »
Goombi
Real Name: Eugen
Post by Goombi »
[quote="Goombi"] I am affraid i cannot give you the specs at this stage but you may be able to figure it out Power bars are 15 mm.5 mm thick.
If this site will let me place a picture you could see it
evric
Real Name: Eric
Post by evric »
Goombi, I have found the easiest way to show an image is to place it somewhere on your own website and then put a link to it on this forum.
Can someone improve on this?
Ric.
Andrew
Real Name: Andrew Brown
Post by Andrew »
You need to goto the "Full Reply Editor" and paste the URL to the image by clicking the Insert Image icon. Either that or upload the picture(s) to your profile through Member Control Panel or select "Upload Image" on the full reply editor.
Simple.
Andrew
Goombi
Real Name: Eugen
Post by Goombi »
For some reasom i was not getting the script window Thanks Andrew
you can also remove the DUDS and also the old postings of mine in buy -sell category   Cheers
