60 Ah NMC prismatic cells 20 kWh *Sold*
Hi all,
I need to sell these prismatic LiYuan cells for Pauline. They were originally going to be installed into her iMiEV, but she needs to sell the car ASAP. So we installed the original battery back in and it's good for about 80 km range. Another sale thread for that soon - maybe $8000?
Anyway, the cells are these ones from Jack Zhang - 3.7 V nominal, 4.2 V fully charged, 2.8 V empty.
The terminals are aluminium and have an M4 threaded hole for copper terminations. I have made up 12 separate polycarbonate boxes (10 for 8s, and 2 for 4s) to suit the iMiEV, but they might also serve as a useful enclosure for any application. Of course, if you want to convert your iMiEV to use these cells you are most welcome - I have the BMS blanking boards and everything. I have the copper buslinks cut up ready for a series installation. It would be ideal to keep the current draw below 20 A as I'm not convinced the threaded pads are all that great. The thread including pictures of the cells and all the gear can be found here:
http://forums.aeva.asn.au/viewtopic.php?p=78295#p78295
Alternatively, the 90 cells would make for a 333 V DC battery which is ideal for any high voltage hybrid inverter like Goodwe ET series https://www.goodwe.com.au/energy-storag ... -278_7.asp or the Fronius Symo https://www.solargain.com.au/sites/defa ... utions.pdf
Any BMS capable of talking to an inverter can work - ZEVA or Batrium works.
Asking $6000 for the whole lot, enclosures, BMS blanking boards for the iMiEV and all. I can arrange shipping at your expense; it might come to $250 or so.
Spec sheet is here:
3.6V60Ah-NMC.pdf
(190.09 KiB) Downloaded 64 times
Re: 60 Ah NMC prismatic cells 20 kWh worth $6000 ono
BUMP!
I need space in my shed. Who wants 90 of these NMC cells? It's about 20 kWh all up.
it's a shame they don't fit in the prelude :(
*triggered*
Not enough of them anyway, it would be both short range and underpowered.
nuggetgalore
Real Name: Andreas Tobler
Post by nuggetgalore »
antiscab wrote:
Wed, 24 Jun 2020, 23:06
Its a shame they do not (easily) fit my iMiEV :(
Still tempted though.
All sold. Guy came around tonight to use them in a storage project.
I still have the blanking PCBs if they are of any use for folks, but I have my doubts.
Re: 60 Ah NMC prismatic cells 20 kWh *Sold*
Post by brendon_m »
Well that's one less thing for you to worry about
nuggetgalore
brendon_m wrote:
Tue, 21 Jul 2020, 18:37
Yep and made the decision for me to not go ahead and attempt a very difficult project.
Well, funny turn of events. The guy who bought them emailed me the next day.
Paraphrasing: The cells are crap! They won't charge past 3.9 V, and they are low capacity! They're junk! I want my money back!!!
I hadn't tested them myself, never even took them out of the box really. So I said sure, return them. He did, and mumbled something about them not being good enough. So I decided to put one on charge and test it today. Took a charge just fine, discharged at about C/2 and it checked out at 60 Ah. The guy was using a crap charger I'd say.
Discharge test.JPG (27.57 KiB) Viewed 241 times
So the best part is that Andreas can buy them now! I'm packing them up to ship on Monday. Good to see the whole lot go to someone who really wants them.
Post by brendon_m »
Crikey, the legacy of that imiev is bit of a roller coaster
doggy
Real Name: David Kerr
Post by doggy »
Interesting he could not charge beyond 3.9V. That would have lost him 12AH (judging from Chris's graph). I agree, sounds like a battery charger issue. Perhaps he was using something set for a different cell chemistry.
Dave
He was probably using a lab power supply not a charger. No point getting the power supply to put out 4.2v if there's voltage drop on the leads. It's why an actual single cell charger has separate voltage sense leads
