First drive of industrial ac hilux
Post by a4x4kiwi » Thu, 26 Feb 2009, 14:51
After a trip to the local weighbridge, I now have the EV Grin!
... and in the excitement I forgot to take a photo or video. arrgh!
The total weight is as expected.
Front: 628kg - 41%
Rear: 916kg - 59%
Total 1544kg.
The original dry curb weight was 1265. 58%F 42%R
279kg heavier
First run efficiency is 2.4kwh / 7.2km = 333kwh/km.
The silly thing with the Danfoss is that I think that the 2.4kwh includes driving and regen.
Points to note:
This is not counting regeneration.
I was driving quite aggressively, but not fast. Max speed was about 60kph.
I live at the top of a 100m hill.
The motor and controller were only warm to touch, even after a 100m climb in less than 1km.
Regen was set at 20% (3kw)/. I should be able to increase this to 66% (10kw) to have the diesel braking effect.
I have the tachometer reading kW but unfortunately it peaks at the motor maximum (15kw) so is not very useful. I will switch tacho back to RPM.
Post by Electrocycle » Thu, 26 Feb 2009, 15:41
good stuff!
I'll have to come and have a look some time :)
Post by Richo » Thu, 26 Feb 2009, 17:31
good work Image
Post by acmotor » Thu, 26 Feb 2009, 17:34
Great work !
True, the Danfoss counts regen as part of total kW (it is thinking of motor thermal ). I look at the torque direction in data file and also my add on battery current measurement to establish regen component.
Post by Johny » Thu, 26 Feb 2009, 17:43
Great news Mal.
lachlanmac
Real Name: Lachlan Maclean
Post by lachlanmac » Fri, 27 Feb 2009, 04:33
It is so exciting to make that first drive. Heart in mouth, giant grin and the desire to shout loudly "I did it"
Well done
Lach
Dean
Real Name: Dean
Post by Dean » Sat, 28 Feb 2009, 00:35
Ive been "lurkin" on here for quite a while, and ive followed your posts. Great work your inspiring me and other lurker's im sure.
Post by antiscab » Sat, 28 Feb 2009, 07:29
Welcome Dean.
feel free to lurk, its the first step towards obsession :D
Post by woody » Mon, 02 Mar 2009, 20:46
regarding the pickup being too slow/course, can you insert a micro inline which multiplies the pulses.
Nothing fancy
e.g.
the last two "real pulses" were X ms apart
send 10 pulses X/10 ms apart.
If you don't get the next pulse, don't send any more pulses.
If you do get it (early), just start again (discarding any unsent pulses).
cheers,
HeadsUp
Real Name: Mark W
Post by HeadsUp » Tue, 03 Mar 2009, 07:05
hi Mal , great work mate
got a question regarding the motor mounting bracket , it looks like about 5 mm sheet ?
i think mine will be around 8 mm bisalloy , which is a higher strength steel than mild steel
bisalloy is 800 Mpa , mild steel is 400 Mpa , so i can use thinner steel and save weight .
i will probably get an engineer to check the maths before i build it though , these things can put out very high torque, and the electric motor mounts are closer together than the original motor , so they really need more strength around the motor mounts
cheers , and enjoy the driving . looking forward to it myself
Post by a4x4kiwi » Tue, 03 Mar 2009, 22:03
WAHOO. Just past engineering signatory inspection.
He was dissapointed he couldnt make any suggestions or reccomendations : Image
Post by woody » Tue, 03 Mar 2009, 22:41
Congrats, great work!
Post by a4x4kiwi » Wed, 04 Mar 2009, 00:09
@woddy. Thanks. Not far to go now.
@HeadsUp the motor mount is flat steel plate. 5.2mm think (from memory), let me know if you need exact details.
Now that it has passed muster. I can mention that it is bolted straight to the chassis as there is minimal vibration and as it is an induction motor, no shock loading. :)
Post by a4x4kiwi » Sat, 07 Mar 2009, 20:11
Today I am road legal!
I can see I still have some controller tweaking to do, but I am done!
Post by Johny » Sat, 07 Mar 2009, 22:15
Great to hear Mal!
HeadsUp
Real Name: Mark W
Post by HeadsUp » Sat, 07 Mar 2009, 23:56
good onya Mal
i am guessing thats a heck of a lot of hours of work
400 plus hours ?
EDITED....... maybe a tad more than 400 hours then   Image
anyway mate ....... while youre out driving , could you pick up the newspaper for me and drop it in to my place on your way ?   Image
enjoy !
Post by a4x4kiwi » Sun, 08 Mar 2009, 15:54
Rattrap
Real Name: John
Post by Rattrap » Sun, 08 Mar 2009, 16:22
Well done mal, congrats!
Post by acmotor » Sun, 08 Mar 2009, 19:50
Hey Mal, I like the 'torqo meter' I want one.
What scale have you used, Nm x 100 ?
Note with the multicharger system, take note of the startup DC bus voltage after recharge. I drove off with one battery module not recharged as there had been a blow fuse ( my doing Image ) in a charger. Fortunately I was looking at voltages at the time and was so alerted to the problem.
Post by Electrocycle » Mon, 09 Mar 2009, 02:25
what's the range like?
You can come and visit and charge up for the home trip if you like :P
Post by EV2Go » Mon, 09 Mar 2009, 19:51
Congrats Mal, great to hear your mobile (unlike me who became unmobile over the weekend Image)
Post by a4x4kiwi » Tue, 10 Mar 2009, 04:33
Here are some observations after a longer drive today:
First of all. What fun!
Now for some stats.
24.6km Very hilly terrain
Start voltage was 657v. 100%SoC according to the greensaver battery data sheet.
End voltage was 621v. 50%SoC.
Energy used (if you consider voltage an accurate means of measuring SoC) = 6kwh. Efficiency = 250Wh/km
I am mixing measurement units here however, the kwh counter read 8.2kwh. This is motor energy both driven and regen. This gives 2.2kWh regen which I find very hard to believe, considering the charge efficiency will not be great.
For now I will rely on the pack voltage for SoC while stationary. I have printed out a lookup table to translate voltage into SoC.
I had the regen set for 10kW (66.6%). This gave over voltage warnings (801+ volts) and was a bit much for the batteries at 16v per cell, but did not trip on a full charge. This equates to a charge current of 12.5A. minus about .5A through the balance circuit.
I have backed this off to 8kW (53.3%) to try and minimise over voltage on the batteries.
Motor heat:
As I live in a very hilly area, the motor is heating up a lot when stationary. I will use Tuarns example and add a 12v cooling fan to the motor.
I am looking at a 10" radiator fan adapted to replace the existing mechanical fan.
I will use a 'clickson' switch to allow the fan to continue running when the vehicle is off.
Post by antiscab » Tue, 10 Mar 2009, 04:40
EV2Go wrote: Congrats Mal, great to hear your mobile (unlike me who became unmobile over the weekend Image)
this seems like a recurring theme....
both my EV bike and ICE car died last weekend aswell.
coincidence? :(
Post by acmotor » Tue, 10 Mar 2009, 07:41
Mal,
What was the kW to recharge the pack ? Oops, tomorrow for the data ?
If you were in hilly terrain, then regen will be considerable. 30% is not unrealistic. Regen kW that is, not all accepted as recoverable charge by battery pack unfortunately ! The ultra caps you ordered will fix that.
If the emotor is heating up, it is probably still losing sync at times.
Did the inspector drive the electrolux ? or did you hog it all ? Image
Any more video ?
Matt, do you need to start an ashes to ashes thread ? Image
Post by antiscab » Tue, 10 Mar 2009, 07:53
im right now, my new contorller is on its way Image
uve just hit 1000 posts btw [:0]
