hmm good thing I do have reduction unit laying around. I have alot of other things to get through before that, thanks for the info though, it helps.smokinjoe wrote: ↑Sun, 01 Nov 2020, 10:07Hi Klemmy,So what are you using to couple the Leaf motor to the VW transaxle? I have a Sterling ( in Australia, it's the Eureka) that i'm going to convert over to electric.
I've just seen your post haven't been online for a while. I wish I had photos of it, I basically had the input of the Nissan leaf reduction unit machined so the clutch centre from the beetle would press in. then I tack welded it to stay there. there is a pilot bearing in the middle of the coupler to keep it centred.
[ Edited Coulomb: fixed quoting (first tag should not have the slosh character). ]
Smokinjoe's Beetle conversion
Re: Smokinjoe's Beetle conversion
- Real Name: Joseph wilson
Spent a bit more time on the beetle this weekend, wired in the 240v charge inlet and interlock to prevent driveway, and plumbed in a small radiator to keep the whole lot cool. Just have to secure some of the wiring and i'm all finished in there.
- Attachments
- PXL_20201122_030328351.jpg (2.65 MiB) Viewed 6021 times
- PXL_20201122_030324709.jpg (2.77 MiB) Viewed 6021 times
- brendon_m
- Real Name: Brendon McCarrol
Nice, liquid cooled beetle
I assume there was no neat way of using the original beetle fill port for the power inlet?
Looks awesome mate! Hope to see it at a meeting, or at the very least Electrikhana 2021!
- Adverse Effects
- Real Name: Adverse Effects
the full conversion looks so neat
Thanks Chris, I'd love to get it up there for electikhana. Hopefully it's all finished by then.
Cheers Brendan, I was hoping to put it there but it would be a tight fit and I was a bit worried about the weather getting in.
I’ve been lurking for a while now but it’s time to get serious. I’ve just taken over a stalled 72 Super Beetle project. It’s supposedly complete but stripped to the last nut and bolt but in boxes with everything bagged and tagged.
It has IRS but I know the gearbox/transaxle needs a complete rebuild. Smokinjoe points out that the Leaf unit would require a modified firewall if it were to be kept as one piece. Here’s my first silly question (there will be more) does the Leaf unit have to be run in its original attitude? If it were run horizontal with the transaxle to the front might it be possible to fit it under the firewall? Not recommended with a regular ICE due to problems with lubrication but does anyone perceive any such problem with the Leaf?
Chris
Chris
- Real Name: Francisco
I don't think it will make any difference. Most diffs' lubrication is by splashing the oil around. So as long as the main gear is touching the oil it should be fine. If you want to be absolutely right you can open the gearbox and check if it has a pump. If there is a pump you just need to make sure it can pick up the oil in the new orientation.
- brendon_m
It will also probably have oil sprayers on the stator for cooling, along with little catch cans for the oil to drip into certain places which may require gravity to get the oil to the right parts. That's being said, I tend to agree with @francisco.shi, there should be enough oil splashing around to make the diff work fine but ideally you would want to see one in pieces especially if theres an oil pump for the cooling side of things (which Im pretty sure there is)
The motor is water cooled. It has separate cooling for the motor and the motor and gearbox are sealed separately.
A friend is using a leaf motor for a conversion and the gearbox is sealed from the motor.
- brendon_m
Ah yes of course. The motor splits off the gearbox easily so it wouldn't use the same cooling system
Thanks guys, I’ve been looking at the Performance EV videos on cramming a leaf unit into a 911 Porsche and while he might be avoiding engineering certification problems by not cutting into the structure I think that in Qld I would probably still need to consider this for the motor mounts. Adapting half shafts between the Leaf and Beetle rear ends doesn’t look like it’s too much of a problem.
At least a year’s worth of basic work to do yet on the rebuild while looking at the conversion options but it’s nice to know that this forum is supportive. I’ve just spent a happy 4 years rebuilding a ‘54 MG TF and couldn’t have done it without the help of the forums. I suppose I should start my own thread now that I have dipped my toes in the water so to speak and declared my intention to do the conversion.
Regards to all for the festive season,
Chris
Chris
I can confirm the reduction unit is splash lubricated, I found an old photo of when I first split the motor, gearbox and charger, not the best photo but you get an idea of orientation. Best of luck with the super beetle Ctwidle.
- Attachments
- 20190630_110211.jpg (2.98 MiB) Viewed 5857 times
- Scotty T
- Real Name: Scott Taylor
Great project, have passed the link to a mate with a Beetle who was thinking about conversion.
Loved the test drive video! What a zippy Beetle!
How has the project been going since?
Thanks! Yes it is a zippy little car. The project stalled for a bit with BMS issues. I ended up making a zeva system which was a big learning curve! The bonus with that is the built in isolation monitoring. An engineering report was done about a month ago. I got the big news that licensing have approved the modifications, So it goes for inspection soon then it'll be on the road!
- Attachments
- PXL_20220120_091948321.jpg (2.46 MiB) Viewed 4151 times
- PXL_20220307_125555797.jpg (2.78 MiB) Viewed 4151 times
- PXL_20220103_032555149.jpg (2.36 MiB) Viewed 4151 times
- PXL_20220103_032543790.jpg (2.79 MiB) Viewed 4151 times
There is another converted EV on WA roads! I picked up the plates on Tuesday, just in time for the Easter break. Now for some range testing and joy rides with the family.
- brendon_m
Congratulations
Hope to see it around at some point
Awesome news! Looking forward to seeing it on the road!
Cheers Guys, It's a bit of a relief to have it on the road finally! Took the bug for a spin with the family today, a good chance to do a range test. We did an 85km run doing mostly between 80km/h and 110km/h and hit the 20% alarm a couple of km from home. I'm pretty happy with that considering the small battery pack and I had a family of 4 crammed in! It could do with a wheel alignment too which should help a bit. I'd estimate 100km highway and comfortably 150km around town.
Awesome stuff. Congrats. I visited Unique EVs in Bibra Lake yesterday and there appears to be a few more VWs that will be on the road soon too.
Thanks Fred! Yeah I've seen their stuff on social media, they do some tidy conversions.
