Qld Moke
wovenrovings
Real Name: Daniel Mulder
Qld Moke
Post by wovenrovings »
Hello Everyone,
So I was so taken by the idea of an electric mini moke that I have acquired one with the aim of converting it.
This is the very beginning of the journey. First step will be repairing the body and refurbishing the running gear. Like all old mokes it is a bit of a rust bucket. :roll:
I have been watching Brendon_m_mokes thread and have take some inspiration from it.
If anyone has any suggestions for an engineer to work with for getting the conversion approved, they would be much appreciated.
I'm in Bundaberg.
Dan007a
Real Name: Daniel Andrews
Re: Qld Moke
Post by Dan007a »
Bills machinery has a few dc forklift drives their might be of interest
wovenrovings
Re: Qld Moke
Thanks Dan007a I will check them out.
Re: Qld Moke
Post by brendon_m »
Oooo.
Congratulations. The best part about converting a moke is they have no features, so you don't have to worry about making them all work :lol:
I was lucky when I bought my because the guy I bought it off was a boiler maker and had cut all the rust out so I've never had to deal with the copious amounts of rust mokes are notorious for.
On the other hand there is only 2 curved panels on the moke (bonnet and the centre tunnel of the floor for those playing at home) and they aren't exactly complex shapes so rust repairs are normally fairly easy.
Good luck and I'll be following your progess
wovenrovings
Re: Qld Moke
So I weighed it last night. 599.6 kg.. :)
Yes Brendon_m I noticed the lack of features. Interestingly mine has a windscreen washer bottle but no washer nozzles or pipes....
There is no sign of a demister either.
wovenrovings
Re: Qld Moke
Quick update. Have stripped the moke down for rust repairs. In the mean time working out the details of the motor and batteries. The part that I am mulling over at the moment is the gearbox. Whether to to with trying to mate the motor up to the moke box and be able to use standard cv shafts or go with a more compact and easier to contect to gearbox out of a modern front drive car and need special cv shafts. Anyway a while before I have to make that decision.
P1090649 (Medium).jpeg (150.05 KiB) Viewed 817 times
Re: Qld Moke
Post by brendon_m »
I'd say find an aftermarket replacement to the gearbox because using it is a pain, on the other hand I never found a reasonable cost alternative.
wovenrovings
Re: Qld Moke
Well I can get a diahatsu sirion gearbox from the wreckers here. Shouldn't be too expensive.
