Qld Moke
wovenrovings
Real Name: Daniel Mulder
Qld Moke
Post by wovenrovings »
Hello Everyone,
So I was so taken by the idea of an electric mini moke that I have acquired one with the aim of converting it.
This is the very beginning of the journey. First step will be repairing the body and refurbishing the running gear. Like all old mokes it is a bit of a rust bucket. :roll:
I have been watching Brendon_m_mokes thread and have take some inspiration from it.
If anyone has any suggestions for an engineer to work with for getting the conversion approved, they would be much appreciated.
I'm in Bundaberg.
Dan007a
Real Name: Daniel Andrews
Re: Qld Moke
Post by Dan007a »
Bills machinery has a few dc forklift drives their might be of interest
wovenrovings
Re: Qld Moke
Thanks Dan007a I will check them out.
Re: Qld Moke
Oooo.
Congratulations. The best part about converting a moke is they have no features, so you don't have to worry about making them all work :lol:
I was lucky when I bought my because the guy I bought it off was a boiler maker and had cut all the rust out so I've never had to deal with the copious amounts of rust mokes are notorious for.
On the other hand there is only 2 curved panels on the moke (bonnet and the centre tunnel of the floor for those playing at home) and they aren't exactly complex shapes so rust repairs are normally fairly easy.
Good luck and I'll be following your progess
wovenrovings
Re: Qld Moke
So I weighed it last night. 599.6 kg.. :)
Yes Brendon_m I noticed the lack of features. Interestingly mine has a windscreen washer bottle but no washer nozzles or pipes....
There is no sign of a demister either.
wovenrovings
Re: Qld Moke
Quick update. Have stripped the moke down for rust repairs. In the mean time working out the details of the motor and batteries. The part that I am mulling over at the moment is the gearbox. Whether to to with trying to mate the motor up to the moke box and be able to use standard cv shafts or go with a more compact and easier to contect to gearbox out of a modern front drive car and need special cv shafts. Anyway a while before I have to make that decision.
P1090649 (Medium).jpeg (150.05 KiB) Viewed 1743 times
Re: Qld Moke
I'd say find an aftermarket replacement to the gearbox because using it is a pain, on the other hand I never found a reasonable cost alternative.
wovenrovings
Re: Qld Moke
Well I can get a diahatsu sirion gearbox from the wreckers here. Shouldn't be too expensive.
wovenrovings
Re: Qld Moke
Sad to say the Moke project has been canned. The more I looked the more rust I found. So I have sold it to someone with more time than me.
On the plus side, it made way for an Imiev...
Re: Qld Moke
The test with old cars used to be that you would hold a magnet up against the panels and wait for it to fall off. You could cover about 2 m^2 before you found some steel :D
wovenrovings
Re: Qld Moke
Yes that's a good test but unfortunately wouldn't have picked up all the rust in the moke. Turned out it had lots of small holes near each other. So there was still steel for the magnet to stick to.
Re: Qld Moke
Sad to see but I can definitely understand. My moke had all the rust cut out before I bought it but I still spent quite a bit of time chasing holes in paper thin metal...
Re: Qld Moke
jonescg wrote: Fri, 13 Mar 2020, 16:22 The test with old cars used to be that you would hold a magnet up against the panels and wait for it to fall off. You could cover about 2 m^2 before you found some steel :D
The car yard panel shops would put iron filings in the bog to make it appear like metal for the magnet test. I've seen sill rails covered with a few sheets of butcher's paper and a few coats of paint to hold it all in place, a few taps with the screwdriver and it would tear a hole in the paper :lol: but it was surprising just how many got caught by the shonky practice. Once the rules came in about having the supply a pink slip when selling a car second hand and then later the car yards having to give a 3mth warranty ended the trick, well in NSW anyway ;)
