TheMechwarrior's - Road Motorcycle EV Project
Nevilleh
Real Name: Neville Harlick
Post by Nevilleh »
Yes, you could strap a generator to the wheels, but you will only get something useful out of it when going down hill. At all other times it will take more power out of your battery than it can put in!
If you use a brushless motor, you get regenerative braking which is the same thing.
Remember the 3 laws of Thermodynamics:
1. YOU CAN'T WIN, THE BEST YOU CAN DO IS BREAK EVEN
2. YOU CAN ONLY BREAK EVEN AT ABSOLUTE ZERO
3. YOU CAN'T GET TO ABSOLUTE ZERO.
TheMechwarrior
Post by TheMechwarrior »
Thanks Nevilleh,
I was just thinking of the dynamo on the front of my old push bike and thinking why can't I do that?
Just found this mob, interesting builds!
http://motoczysz.com/motorcycles
Together Each Achieve More
TheMechwarrior
Found these: http://xa.yimg.com/kq/groups/17042789/7 ... 0Ah_A1.pdf
http://www.dowkokam.com/cell-specifications.php
Would "only" need 26 of them to give me the range I need...I'm expecting they are very expensive. Will see if I can get any prices.
Kokams are very sought after by the serious RC crowd. In that environment they don't last very long but would be longer-lasting if treated better. They are the most expensive cells around. Not sure where I got this info.
Found it - it was here (forum) then I went looking elsewhere.
viewtopic.php?title=geerants-magnatron& ... 300#p29149
"Then came the Kokam Lipo batteries. They were by far the best battery as far as pack weight goes and will give the best range of any battery currently available. However these batteries are extremely expensive and they have substantially less charge/discharge cycles than most other battery types."
TheMechwarrior
Thanks Johny, I saw a cycle life of 800 to 1500 depending on the battery.
I'll keep kicking the can on this and see what I can manage.
I'm also continuing discussions with Zero Motorcycles.
Post by 4Springs »
Another option is to investigate other charging options at work. Do you know who owns the property opposite? They may allow us to charge there. Or charge in Westbury and walk in.
Zero has been using EIG cells, which use a Li(NiMnCo)O2 anode. They offer 175 Wh/kg and one of the highest volumetric energy densities I've seen (370 Wh/l).
However...
Not a lot of testing has gone on in the real world, and I think they are being used in Nissan Leaf packs; they're apparently not really enjoying the heat. Not really a problem on motorcycles though.
Provided you keep the discharge rates below 5C they should perform as the manufacturer intended.
TheMechwarrior wrote: I can't get enough gains out of strapping a generator(s) to the wheel(s)/powertrain?
I certainly hope you realise that you can only get power from the generator to replace friction braking; generating while driving will cost more battery energy than it generates. I proudly obey the laws of physics, and you should too! Image
It's generally considered that adding a generator for regen braking is not worth the effort, weight, space, and cost.
jonescg wrote:Not a lot of testing has gone on in the real world, and I think they are being used in Nissan Leaf packs; they're apparently not really enjoying the heat.
You are correct in that the LEAF uses Lithium Manganese Dioxide (LiMnCO2) cells. The heat problems have really only been experienced in Arizona in the USA - that place is like a sauna. The cells in the LEAF are contained in metal boxes - four cells to a box. The boxes have air circulating around them. In a typical Australian climate I would expect that they are fine however I would have temperature monitoring in them and a reliable BMS and charger as they are subject to the same problems as LiPo - bursting and burning.
TheMechwarrior
I got a reply from Zero Motorcycles regarding prices for the powertrain options they sell independantly of the bikes:
PowerTrains
This is the price list for the 2012 range, the 2013 prices are still to be set.
Retail by unit
Battery pack & charger
ZF3 $4,195
ZF6 $6,195
ZF9 $8,195
Motor
Motor 14 $995 with controller $1,795
Motor 29 $1,195 with controller $2,095
Full kit
ZF3 with Motor 14 $5,695
ZF6 with Motor 29 $8,195
ZF9 with Motor 29 $10,195
zeva wrote: Regarding motors, have you looked at the Motenergy ME0913? Couple it with a 96V BLDC Kelly controller and you'll have a comparable system
TheMechwarrior wrote:Motor 29 $1,195 with controller $2,095
Given that the Motenergy ME0913 looks suspiciously like the "motor 29".
I'd buy the ME0913 at evworks for $850.
Richo - the difference might be the Zero motor could be using thicker magnets and a smaller air gap. Makes quite a difference.
I'd still go evworks since the ME0913 is 30kW vs motor-29 20kW peak.
TheMechwarrior
Thanks Richo, the ME0913 and the L91-4003 are two motors still in the mix.
Just waiting on some emails to come back from cell manufacturers.
I'm chasing up prices on GEB16215160 (1s4p x 30) or GEB 9989182 (1s5p x 36) since they take up so little volume and have great cycle life. When you combine those two elements that's gotta spell expensive I'm guessing.
4Springs wrote: Another option is to investigate other charging options at work. Do you know who owns the property opposite? They may allow us to charge there. Or charge in Westbury and walk in.
Thanks 4Springs, a bloody good suggestion, I'll follow that up!
Mech.
The GEB16215160 just look like standard LiFePO4 in a pouch.
The cycle life look like typical LiFePO4 cells.
But their Discharge rate is a little on the low side.
You would struggle to get 30kW out of a 10kWh pack.
The GEB 9989182 appear to be Li-Ion(3.7V) so the cycle life would be worse.
Given thier low discharge ratings I wouldn't buy them.
TheMechwarrior
Thanks Richo.
Looks like I may have a few contenders for the bike finally, will follow-up tonight and see how I go this week.
Cheers.
TheMechwarrior
These are the bikes that have been offered to me:
1. Triumph Sprint ST955
2. Triumph Sprint ST1050
3. Yamaha FJR-1300
4. Honda VFR800
-approx $1500 for a complete rolling chassis.
Just chasing up year of manufacture and some pics, I'd prefer either of the last 2 with a preference for the FJR due to its size.
I can get cheap aftermarket full fairing kits for both those last two.
Would the shaft drive on the FJR present more problems than chain drive?
TheMechwarrior
Not so much I hope, I've seen kits to deal with this...now is a good time to sort it out though, thanks for the reminder.
TheMechwarrior
Update:
The ebike is on hold for a while.
I managed to secure my motorcycle (2002 Honda ST1100P) and it's in fine working order so I'll keep it that way. When it comes to the end of it's life I'll have the perfect donor bike for my project.
In the mean time I'll keep studying/gearing up for EV bike build.
People have asked about my methods for finding a suitable rolling chassis:
1. Decide on 1 or 2 bikes maximum as wreckers have no time for fielding broad range requests. For me it was ZZR1100/ZX10 or bigger.
My reason was it was heavy, had a lot of fairing to cover the ugly batteries. Full fairing kits are available from china for less than $500. Plenty of room for electrics.
2. Search state by state for wreckers and shoot off an email to them all. For me I stuck to Eastern Australian states, so I had roughly 30 wreckers on my list.
3. Ensure you stipulate rolling chassis is not to be a SWO (statutory write off). Must be a RWO (repairable write off).
4. I managed to find a number of suitable rolling chassis and they all come in around $1,500 but it is possible to get them cheaper.
5. You then need to organise freight.
6. By the time you spend $1,500 on a chassis, ~$500 on flights etc for inspection in person, ~$500 in freight to get it home you may want to consider jumping on www.bikesales.com.au and simply buying a complete running bike as cheap as you can locally.
For me I got a little carried away at that last step and decided to buy the bike I've always wanted. Been 15 years since I had a bike and the dream of riding again got the better of me.
Carv'n Marv'n
Real Name: Simon Williams
Post by Carv'n Marv'n »
Are you in Hobart Mechwarrior??
TheMechwarrior wrote:I managed to secure my motorcycle (2002 Honda ST1100P) and it's in fine working order so I'll keep it that way. When it comes to the end of it's life I'll have the perfect donor bike for my project.
Being a Honda, that should be in about 2031...
TheMechwarrior
Carv'n Marv'n wrote: Are you in Hobart Mechwarrior??
Much further north than that, Spreyton mate.
