Spesc:
Motor: Super Zebo 11kw Sepex DC 144vdc max
Controller: Kelly KDC Regen 120vdc max, with water cooled heatsink
Batterys: REF100 38 x 3.2volt, 100ah (weight 114kg)
Charger: TC TTCH-H161-10
Dc-DC: IOTA 55ah
BMS: Wicom EMS
Brakes: Dual 120vdc vac pumps
Steering: Electric power steering pump from Holden Vectra
Rear battery box fits in place of removed fuel tank.
Under bonnet arrangment
Brake components, 2x pumps, 2x reservoir, vac control switch, low vac warning switch and guage.
I have had an engineer have an initial inspection and all appears to be OK. I only needed a few extra gussets on the front battery box. I had to also install a low vac warning switch, light and buzzer into the system.
I will post a few more photos as i progress.
