I do indeed have a big red switch, which should disconnect +ve (if weber is right) and the logging cables are at a loose end, until I attach one logger to them, so they are 'free'. In theory this leaves only the -ve cable, which snakes out of the Upper battery box and, inside orange flexible stuff, onto the Controller box. It would be very convenient if this were the only cable, and I could leave it, and indeed it does seem to me that is the case. See pic of the red switch and orange flexible conduit.
In tomorrow's light I unbolt (carefully, protecting all possible metal surfaces) then scrape with wire brush all connections and finally coat them with Cabac's grey conducting goop and re-attach. No torsion wrench so it will be a guess, I'll try and do them just like they were at undo time.
Because B45 is the end of the string, it has 3 items not 2... the main battery terminator as well as BMU as well as braided link to B44. In fact this may be part of the reason Im working on it. For the same reason, should I do B22 next door? B22 is its at the other end of the same string... And B44 next door was also problematic in the recharging log, so it will get a scratch too. Then, the point of all the work, I can log another re-charge, and post the results. Whoo hoo! Barney
