Speedily's Dragster
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
1) Find Dragster with a trailer
2) Sale off ICE parts not needed
3) Redesign rear end to chain drive
4) Motors
5) Controllers
6) Traction pack
7) Go racing with a EV grin Image
The Dragster before being striped
Some of the parts sold off
The first look at how i was thinking about the redesigning of rear end to make it chain drive
The motors
Two 11" 250 Volt Kostov that have been madeup to suit the dragster by the guys at Kostov,the motors can series/parallel the fields
Controllers
Two
max volts 340 max amps 1000 but can go to 1400amps for racedays
EV2Go
Speedily's Dragster
Post by EV2Go »
Call me paranoid but the drive shaft looks a bit small Image
Wish I had seen the diff housing before you sold it Image I just recieved mine from Strange on Monday and they look about the same length.
Any pics of the two motors?
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
EV2Go wrote: Call me paranoid but the drive shaft looks a bit small Image
Oh that axle would hold up to .5 hp maybeImage , The axle will be 7075 grade 76mm ID and heat treated
I sold off the whole setup it was all Strange parts too oh well that was 6 months ago
The motors are being build now so all i've got are the draftings but they look like my avatar Image
Tritium_James
Real Name: James Kennedy
Speedily's Dragster
Post by Tritium_James »
Why couple the motors together? Can't you simplify things and have two chain drives, one per motor/wheel? No expensive gearing then, and no need for a diff. Those controllers can regulate motor current, so if you command them both to do the same thing, you'll have the same torque at each wheel, and everything stays straight down the line...
Electrocycle
Real Name: Andrew
MSN: dumhed@dumhed.com
Speedily's Dragster
Post by Electrocycle »
the axle will be solid anyway - no diff required, but I'd still be tempted to run a chain from each motor. The only disadvantage is that when you want to change ratios you have to do it twice.
Thalass
Real Name: Ben Rypstra
Speedily's Dragster
Post by Thalass »
Nice! I think this'll be a project for life! Can't wait to see some times and videos.
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
Electrocycle wrote: the axle will be solid anyway - no diff required, but I'd still be tempted to run a chain from each motor. The only disadvantage is that when you want to change ratios you have to do it twice.
but why run two chains to the back wheels the chain i've got wont break ??
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
Tritium_James wrote: Why couple the motors together? Can't you simplify things and have two chain drives, one per motor/wheel? No expensive gearing then, and no need for a diff. Those controllers can regulate motor current, so if you command them both to do the same thing, you'll have the same torque at each wheel, and everything stays straight down the line...
If i run a motor for each wheel and if one stops working i'm in trouble Image fill power on one wheel is dont gunna end good
Squiggles
Real Name: Neil
Speedily's Dragster
Post by Squiggles »
I thought it was a solid axle? Or was that someone else's idea?
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
Squiggles wrote: I thought it was a solid axle? Or was that someone else's idea?
Yes it is one piece axle and one main drive chain
Electrocycle
Real Name: Andrew
Speedily's Dragster
Speedily wrote:but why run two chains to the back wheels the chain i've got wont break ??
It'd make the setup a little bit simpler to build and for servicing - and you could run two smaller chains instead of one big one.
Either way it'll work :)
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
Controllers are here Image
Performance:
Can deliver 1000A continuously if liquid cooling is used, or for 15-20 seconds out of every 90-120 on air cooling alone. This limit can be unlocked for racing to deliver up to 1400A for short periods only! (hmm 10 sec is a very short time)   Image
Can operate on 10V minimum to 342V maximum
Speedily's Dragster
Very nice controllers. Give the Zilla's a run for their money.
It would be good if there was an Australian distributor - they don't list one on the website. Did you bring them in from the USA?
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
I'm the Australian Dealer Image for them, I'm just getting all the stuff sorted out at this end(website) and then i'll start selling them
Speedily's Dragster
Good! Image
I hope they give you a good margin so the price is reasonable. Image
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
The price is on par with whats out there and i'll be doing a deal or two for the open month Image
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
The start of the twins.. the drive ends are 38.1 diameter
bontar hoklin
Speedily's Dragster
Post by bontar hoklin »
I have been looking for such for quite some time.I saw one of my friends having done it, and looked awesome.Though i admired it,the price made me not purchase it at that time.
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
Update time.
Motors are here so time to start fitting them.
Here are some photos of the build so far
EV2Go
Speedily's Dragster
Post by EV2Go »
Still waiting on my motor, hoping it will be here really soon. It's on the water and should be here any day now.
Anthony did you have to modify the cable contact lid to get it exposed like that or does it just clip off?
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
EV2Go wrote: Still waiting on my motor, hoping it will be here really soon. It's on the water and should be here any day now.
it just clipped off
EV2Go
Speedily's Dragster
Post by EV2Go »
Just looking at the gallery, it's coming along nicely. I can't wait to see it run.. how long before you have it trackside?
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
All going to plan before Christmas :)
Speedily
Real Name: Anthony
Speedily's Dragster
Post by Speedily »
Update time
Haven't got the car going yet, getting alot closer. I have spent the last 4 weeks of spare time rebuilding the trailer and making it a covered in trailer and snug little home for my new baby. All going to plan the car will be on the track end of February. I am starting to get really excited about the impending rush of atrenaline..
There are plenty of pictures on the website of how its all been going.
EV2Go
Speedily's Dragster
Post by EV2Go »
Launching with electric is going to be such a rush, I can't wait to see the videos Image
