Obsolete Thread
- AussieJester
- Real Name: KiM
- MSN: aussiejester@hotmail.com
Power to you but the JAG rear end is an icon in street rods, bewildered why your spending the $$ on ...what your spending it on, power to you
overkill is ...good ...if you can afford it...i guess.. curious though, have you ever ridden a trike? Your a bike rider obviously, if so, i fail to see the attraction of a trike they are the most boring things to ride IMHO..I look forward to this anywayz, no expense spared project should freakin ROCK!!! all the best mate
KiM
KiM
[url=mailto:emissions-free_worldwide@hotmail.com]For A123 Prismatic Cells[/url]
Recumpence.com[/u]...For RC Reduction Drives
http://tppacks.com
http://tppacks.com
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- woody
- Real Name: Anthony Wood
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Electrocycle
- Real Name: Andrew
- MSN: dumhed@dumhed.com
- EV2Go
- Real Name: Paul
- Electrocycle
- Real Name: Andrew
give the batteries their own suspension
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- AussieJester
- Real Name: KiM
That diff wouldnt look out of place on a trophy truck racing in the Baja 1000
KiM
KiM
http://tppacks.com
http://tppacks.com
- Johny
- Real Name: John Wright
Is that all alloy - including the hub flanges?
- Electrocycle
- Real Name: Andrew
- EV2Go
- Real Name: Paul
Any rear suspention with hydraulic shockers with adjustable tension in corners the trike will lean just enough to giwe you the feeling
As soonas the trike has weight in cornering the mercury spring loaded sensor will pressurise the heavy side of the trike from the light one and keep transfering oil from one to another in cornering Just a thought cheers
- EV2Go
- Real Name: Paul
EV2go do you ever visit auto wreckers? they can cut the suspencion anchors and part of suspencion including coils to fit even get a decebt diff --financially comfortable--
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Electrocycle
- Real Name: Andrew
you should be able to get all those holes laser cut at the same time
- EV2Go
- Real Name: Paul
- Electrocycle
- Real Name: Andrew
I think if you mounted the battery box on some "engine mounts" or similar it would be ok - as long as they can handle the impact required.
- EV2Go
- Real Name: Paul
Motor you are chosing surely will have the High and low voltage differenciation 144 volt motor will suffer a stress if you pump 195-250 volt I am not sure what Motor and Controller is to be used but surely there has to be some synchronisation and compatibility-- Controllers are known to explode if abused and burning motors also I have been observing and following your trike with interest would you be needing all this super volt power? Obviously you are chosing high volt for speed low amp batteries for short distance Should that not be the otherway round?
Looking forward for more trike progress ..Cheers
