Page 6 of 24
EV2Go's - Lithium Powered Trike
Posted: Thu, 16 Sep 2010, 02:34
by rhills
I tend to lean towards plastic for light weight and also corrosion resistance. However, here you may also have to worry about UV resistance, any idea how the plastic will stand up to UV?
What about price, up front and also if it has to be replaced down the track?
FWIW, the shiny plastic one looks nicer and I like blue!
Posted: Thu, 16 Sep 2010, 03:27
by EV2Go
by Electrocycle
I found an old metal one I'm going to use on my bike because it's easier to modify
Posted: Thu, 16 Sep 2010, 04:31
by EV2Go
Posted: Wed, 22 Sep 2010, 22:25
by EV2Go
Posted: Fri, 01 Oct 2010, 06:30
by EV2Go
Posted: Wed, 06 Oct 2010, 22:30
by EV2Go
Posted: Thu, 07 Oct 2010, 00:14
by Speedily
The green motor looks like its got a whole new end cap made
Posted: Thu, 07 Oct 2010, 01:10
by EV2Go
Posted: Thu, 07 Oct 2010, 01:55
by Speedily
Looks good
Posted: Thu, 07 Oct 2010, 04:34
by EV2Go
Posted: Thu, 07 Oct 2010, 06:43
by EV2Go
Posted: Thu, 07 Oct 2010, 09:49
by Speedily
lol This is how i'm doing it
one of the injector hats mit look good on the end of the intake
Posted: Thu, 07 Oct 2010, 17:10
by EV2Go
Posted: Thu, 07 Oct 2010, 17:55
by EV2Go
Posted: Thu, 07 Oct 2010, 18:09
by Johny
It would be way more exciting (for us) if you ran the motor and held a hacksaw to the shaft.
No, I would not rest the armature on the field laminations while anything vibratary (word?) was done..
Edit: added 't'
Posted: Thu, 07 Oct 2010, 18:23
by EV2Go
Posted: Thu, 07 Oct 2010, 18:43
by EV2Go
Posted: Thu, 07 Oct 2010, 18:54
by Johny
Agreed - just take is easy and check temp. every now and then.
Are you sure you don't want to think about this for a day or two?
Removing all of the rear-end of the shaft may make putting a tacho or encoder on to the motor a bit more difficult.
Posted: Thu, 07 Oct 2010, 19:46
by EV2Go
Posted: Thu, 07 Oct 2010, 21:12
by Speedily
Paul the criclip fan and spacer set the end float of the motor
Posted: Thu, 07 Oct 2010, 21:22
by EV2Go
Posted: Thu, 07 Oct 2010, 22:31
by Speedily
whats holding the front bearing inplace
Posted: Thu, 07 Oct 2010, 23:21
by EV2Go
Posted: Sat, 09 Oct 2010, 15:20
by AirAg
How did you manage to get your menu items to link to your following posts? I have just been replying to my first post when I put up new stuff and it looks like the URL is the same for the whole topic.
