Obsolete Thread
Locked
EV2Go
EV2Go's - Lithium Powered Trike
Post by EV2Go »
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
GRMarks
Real Name: Glenn Marks
Post by GRMarks »
EV2Go with yoyr tike so low how will it tilt ? I don't see ant pivot points in the frame anywhere so I assume the whole frame will tilt.
Regards
Glenn Marks
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
Electrocycle
Real Name: Andrew
MSN: dumhed@dumhed.com
Post by Electrocycle »
even if the shocks go vertical, you could just have a small cutout in your battery pack area for them.
Are you putting batteries behind the diff too?
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
I've worked with taper locks in heavy industry. We used them to hold the pinion gears on the hydraulic motors to drive the winch drum and luffing drum for some of the smaller site cranes, up to around 22 tonne lift from memory. Also used a lot for drive couplings. I can't give you any specs for grip area required unfortunately, every thing in heavy industry is over build by a large margin to cover everyone’s butt. I know they are an absolute pain in the butt to tension up. Criss-cross tensioning around and around till there is no more tension to be had on any of the grub screws. Have a cup of coffee and start again. You can't rush it or take any short cuts because the taper lock will bind and then the whole thing needs to come apart again, polish off the nicks and start again. Oh what fun but done properly they don't slip.
The bearing mobs will have a techo bloke who can give you all the min requirements surely.
EDIT: for atrocious spelling
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
Post by woody »
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
Speedily
Real Name: Anthony
Post by Speedily »
you dont have to keep them in one box
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
Post by woody »
Hi EV2Go,
the 40160S are 500g, 40mm x 160mm cylinders
Deliver up to 160amps at 2.4V (384 Watts)
16 Ah capacity, 70-80% usable.
the 38120P are 330g, 38mm x 120mm cylinders
Deliver up to 160amps at 2.4V (384 Watts) - i.e. the same amount
8 Ah capacity, 70-80% usable. (half the amount)
So for about 60% of the cost, 66% of the weight + size, you can get the same power output, but only for half as long.
Or, another way, 10% cheaper, same size + weight, you can get 50% more power, 25% less range.
cheers,
Woody
EV2Go
Post by EV2Go »
Post by Adverse Effects »
why not use flanges and a disk brake off a small car
you have to remember the braking will be multiplied by the diff ratioImage
Speedily
Real Name: Anthony
Post by Speedily »
the braking load would be divided by the dife ratio not multiplied. a small point :-)
Locked
