Woody's 1963 Ford Cortina
I think you've missed something in the whole going green concept there Woody Image
A box, which I assume contains my motor, has arrived!
Open it - open it! Image
Unfortunately, where it has arrived (which has a loading dock) and where I am (which doesn't) are two different places, separated by 20km, and I have no car with me :-( So possibly later in the week...
Sooo close yet so far Image
Can't you complain of stomach cramps run out the door hail a taxi and go for it Image
Johny wrote: Open it - open it! Image
Plate looks right:
Serial No ends in 00001
110 DD 50 1445 18,50 132,50 0,82
220 D 50 1445 18,50 66.30 0,82
92,00 kg
12 Terminals as requested!
The shaft turns. That's all I did at midnight :-/
It's not enough - I want more! Like which end of the motor is the terminal box on (OK I could look up the motor), but that's not the point. Is it at home now?
The terminal box is at the drive end. It's quite big (~ 200mm square), but low and flat. In the photo above you can see the flange mount and some shine reflecting from the shaft.
It's at home, so I'll take more piccis with a proper camera and measurements on the weekend. The above were taken with a camera phone using a keychain legoman torch for light :-(
The fan cover is plastic, there is no shaft beyond the cover.
The box is cardboard.
That's all I know.
woody wrote: The terminal box is at the drive end. It's quite big (~ 200mm square), but low and flat.
Make that 180mm square:
Protruding 35mm above the flange
Extending 80-260mm from the drive end, the highest part being 105x105mm
The aluminium stator is 470mm long, the drive end on a flange about 320mm diameter, the fan end a 300mm square with 60mm right isoceles triangles cut from the corners.
A much better shot of the Plate:
And dialectric and functional tests from a month ago.
Made in Spain.
12 Lead lets you wire series or parallel and star or delta:
So I can wire for 110, 190, 220, 380V AC @ 50Hz
The terminals in the photo are:
W1 V1 Y1
W5 V5 Y5
W2 V2 Y2
W6 V6 Y6
links are included for:
1-5 and 2-6 for parallel, 5-2 for series
Power to W1 V1 Y1
Short W6 V6 Y6 for Star
Connect W1-V6, V1-Y6, Y1-W6 for delta
I could possibly join 2-6 for dahlander 2 pole series or 1-6 + 2-5 for dahlander 2 pole parallel, but I'm pretty sure that won't be as efficent and may not work at all depending on how the stator is wired.
Apparently, the done thing with 12 terminal motors is to move the stator wires about so you can just use copper links for all jumpers...
ebay provided an unused 11kW VFD - Telemecanique / Square D Altivar 18 for $300 including postage.
This will probably live in the generator trailer eventually, but it's big enough for testing. So I have the main parts for the generator trailer now:
11kw 2 pole 132 frame
Kent 1200cc motor (Currently driving the cortina around)
VFD
Trailer
Still need a precharge for the VFD.
Is the VFD a ATV18D16N4?
woody wrote:Still need a precharge for the VFD.
From this paragraph:
"When commanding the power by line contactor, avoid frequently opening and
closing the line contactor which could cause premature failure of the filtering
capacitors and precharge resistor. Use inputs LI1 to LI4 to command the drive.
Limit operations of the line contactor to less than once per minute."
I get the impression that a precharge resistor is built into the drive.
yep. ebay listing has everything I know.
I haven't had a good look inside yet. It's still under my desk at work.
PA + PC seem to be the DC bus. The precharge may be between the rectifier/scr/whatever and the bus, not between the bus and the terminals. I'll bring it to the Sydney AEVA meeting and some engineers will look at it and tell me without me asking :-)
The 12 terminals make sense now the Wye / Star option is the AC eqivilant of my 6 terminals for Series / Parallel.
Johny wrote: I get the impression that a precharge resistor is built into the drive.
Taking the covers off to have a look...
Having a look around it kind of looks like this circuit:
So I'd say that there's a precharge circuit built in, and it's in the right spot.
They've gunked up the (unlabeled) P0 and PC screws, so I need to ungunk them, but that should be easier than my own precharge circuit.
Good. Nice simple precharge system that says "please use me with batteries". Why'd they go and gunk up the DC Bus connections. B*&^&^%ds.
7circle
Real Name: Ken
Post by 7circle »
Have you looked at the Bridge from the mains.
Some of them have SCR's that allow pre-charge from the AC Mians but might not be helpfull running from DC.
They could be replaced with an IGBT block and use the signal that normall y goes the the SCR gate drivers to enable Soft inverter PWM to the IGBT block.
7circle wrote: Have you looked at the Bridge from the mains.
Not sure what I'm looking for, but here's an image I forgot to attach above
He doesn't have any SCRs. This unit just uses a resistor and relay bypass when voltage has reached a specific value. No problem.
johnfriartuck
Real Name: john
Post by johnfriartuck »
hi not wanting to interfere but isnt it kinda defeating the object to run the old engine to power the new one, if your gonna tow a trailer bhind you why not replace the axle with a live axle out of say a cortina(just an example) and use the diff to power the generator as its being pulled along (easy to set up)and charge a spare set of batteries in the trailer then just switch em over every time you need to, im not an electrician tho so it mite be a dumb idea(there always seems to be some reason why things cant be done) just imagine, if its practical, setting up more than one 240v gennie to run off the diff,dont laugh too hard dont want anyone busting anything
One tiny problem JFT a little thing called friction, unfortunately you consume far more energy generating the power than you would get from it.
Sorry no free lunches, the energy has to come from a source other than the vehicle. i.e solar, can't even use a wind turbine while driving same loss in making the power.
Hi & Welcome!
johnfriartuck wrote: hi not wanting to interfere but isnt it kinda defeating the object to run the old engine to power the new one
Yes, a bit. It kind of turns my EV into a hybrid with a very heavy + long continuously variable transmission. But I only want the trailer for:
1) The odd long trip by me or other EVers
2) Keeping my old engine in working order
3) Fast charging?
Any energy I'd pull from a trailer like this would take extra energy and then some from the car batteries - no free lunches I'm afraid.
When I started reading I thought you were going to suggest something like this but I don't think the Australian authorities would like it much.
