Francisco's Electric Pajero
Re: Francisco's Electric Pajero
So many pipes. It's great that the battery will be liquid cooled, but it seems to me that there will be hundreds of potential places where coolant could leak out. Ask Chris Jones about leaking battery modules.
Will the coolant be distilled water based, or some other relatively low conducting liquid?
MG ZS EV 2021 April 2021.
- Real Name: Francisco
Leaks are a concern. The joints at the end of the pipes have two orings. I am also (seriously) considering potting the ends of the pipes and the manifold.
I will probably be using glycol coolant.
What I am planning to do is to test the battery without coolant and make sure everything functions correctly before potting the ends. I could also use a soft potting compound that can be removed in case I need to do repairs.
I guess it is difficult to get good compactness and serviceability. I think the new Tesla modules are also potted but even if they weren't you couldn't easily replace some dead cells.
Making more progress on the left hand side module.
Got parts ready. 3 more layers to go.
I hope I can finish this module tomorrow.
Most of the time is used wrapping the cells, folding the tabs and cleaning the tabs and applying contact grease.
Bottom of the left module is assembled and now compressing the cells.
I will try to finish the top modules some time this week.
This is the largest module. It should be around 90kg.I will try to finish the top modules some time this week.
Battery module removed from the jig and placed roughly how it will fit in the battery case.
There are still 3 more small modules to go on top similar to the right hand side.-
Finished the 3 top modules.
Now just the small center module missing which is 18S.
The separation of the modules is about right so this is the rough size of the battery pack.
I now need to make some plastic spacers to go between the horizontal and vertical blocks, add the bus bars and clamp everything together into two single units. Make sure I can get the bus bars from the terminals of each unit to the right place.
After that I need to get the battery box prototype that is in the car and put the two blocks in and update the drawing. After that i need to get it made and hopefully everything will fit in the car. I still have not thought about how to get all the cooling pipes connected together to ensure I get the same flow thru each string and to make sure I can get the inlet and outlet hoses in an accessible place.
It is getting to the point that it is difficult to visualise this in the CAD model. Some times real parts are easier to figure out.
34S on the right hand side and 44S on the left hand side for a total of 66kwh.Now just the small center module missing which is 18S.
Wow. All that and more has to fit into one vehicle? It doesn't look possible. It will be interesting to see the installation photos.
It does fit. There is a lot of space under the floor. The box that all this is supposed to fit into (according to the CAD model) is already in the car. It is just empty at the moment. If it wasn't because the motors encroach into the battery I could get 100kwh.
Today I made the spacers to go between the modules.
The spacers have grooves to match the pipes on the bottom module and has the shape of the top 3 modules. These spacers keep everything locked so nothing slides.-
Spacers installed. I also made some manifold dummies to see how it will fit. I haven't decides how I will do the liquid routing so I don't want to make the proper manifolds yet.
There were a few difficulties during assembly. I found that I need to come up with a better method of applying the correct compression. I have had to re do the crimping because they were compressed too much and the spacers didn't fit correctly. I have also added some shields for the bus bars.
If I can get it finished I will try to bring this module on Wednesday to the meeting.
I got most of the straps done. Just missing bus 3 bus bars (about 200g extra). All the other links are in.
The total weight is 150kg for 31.5kwh (210wh/kg).
That's looking rather monstrous! It must feel good to finally be getting the batteries together.
Two questions:
Two questions:
- What will the total battery box weight and capacity be?
- How're you going to lift what's on the table? Is it rigid enough to support its own weight?
The block on the table is very strong. If I put a block of wood on each end to hold it off the table I can stand on the middle without any problems. I took it to the AEVA meeting for show and tell. I used a piece of RHS with two straps and an engine hoist to lift it.
The total capacity of the battery will be about 85 kWh. It should weigh about 400kg for the battery modules, about 40kg for the case and about 70kg for each motor. So total going in will be about 585kg. I am hoping the engine, gearbox, transfer case, exhaust and fuel tank will be about 500kg may be more. The fuel tank with fuel alone is 100kg.
It is exciting getting the battery together but there are so many small parts that I need to make and they take a lot of time.
There are 3 bus bars missing in the picture. I have done two already. Still one more to go. There are some isolator blocks to allow the bus bars to go thru the cooling manifolds which I hope I can do tomorrow and then one more link on the back and it should all be done except for the real cooling manifolds and the BMS boards.
The block that goes on the other side has onr bus bar that is a bit complicated and I still haven't got a good solution for it but will see how it goes.
